Bronco Custom 1979 400 rebuild
Hi Guys, Im from Argentina and this was my engine rebuild project
Bronco 400 with TMI pistons, the first one here.
this is my 79 bronco custom, it has a 351M engine with C6 auto trans.
I got 400 crank and pistons, and I´ll swap the C6 for a ZF5 manual trans.
I turned off the engine in may 2010...
Tmeyer sent me these
400 Hypereutectic Piston 9,3:1
Premium Rings
Kit Gasket Set
Expansion Plugs, Brass
Oil Pump
SBF Lifters
"335" series-Gear Drive-Quiet
Ultra Slick Engine Assy. Lube
Plastigage
ZDDP oil additive- 4oz. bottle
Cam Bearing Set- Grooved
Valve Spring, Retainer and Locks kit
HARMONIC BALANCER
Engine Bolt Kit- 351M/400
400 Crankshaft Kit
rod and Main bearings
351M/400 Push Rods
BBF Roller Rocker Arms
1.650" Exhaust Valve
2.040" Intake Valve
351M/400-Water Pump
Premium Rings
Kit Gasket Set
Oil Pump
SBF Lifters
Plastigage
HARMONIC BALANCER
400 Crankshaft Kit
351M/400 Push Rods
2.040" Intake Valve
351M/400-Water Pump
