Knuckle and brakes help! - Ford Truck Enthusiasts Forums
Old 11-11-2012, 11:28 AM
czgunner czgunner is offline
czgunner is starting off with a positive reputation.
I'm using a narrowed 1978 F250 Dana 44 in the front of my Jeep.
I am converting it to 1/2 ton brakes so I can use the 5 on 5.5 wheel pattern.
I have everything from brakes out from the 1/2 ton truck, but I still have the F250 knuckle as I haven't found the smaller knuckles yet.
Can I use the 1/2 ton outers with the 3/4 ton knuckles?
Old 11-13-2012, 11:59 AM
bigdan1979f-250's Avatar
bigdan1979f-250 bigdan1979f-250 is offline
bigdan1979f-250 is starting off with a positive reputation.
I don't think this is possible. I have a 79 f-250 and I know for sure that the spindles, hubs, and brakes/brackets are totally different. I think you would be time, money, and aggrevation ahead to just buy either adapter spacers or just buy 8-hole rims
5 lug to 8 lug TIB (2wd) PlumCrazy* 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 06-26-2014 10:10 PM
1/2 ton to 3/4 ton stromburg 1973 - 1979 F-100 & Larger F-Series Trucks 1 10-17-2012 10:33 AM
difference between 150 and 250 frames? jello 1987 - 1996 F150 & Larger F-Series Trucks 23 04-30-2009 04:50 PM
D44 8 lug to 5 lug conversion questions... 460 Offroad & 4x4 3 04-09-2007 05:19 PM
dana 44 3/4 ton knuckles on 1/2 ton axle fords_forlife Offroad & 4x4 1 06-30-2006 03:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
