Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-10-2012, 07:13 PM
kennypowers13 kennypowers13 is offline
Garage is empty, add now
kennypowers13 is starting off with a positive reputation.
Perplexed
I've been a mechanic for many years. Recently I went through a change of life, went from living comfortable to just getting by. So now money's tight. I found a deal of a life time recently. I found a 99 f-150 with 136000 on the clock, beautiful truck inside and out. The lady said it was running rough, and immediately I though vacuum leak, which it turned out to be. After fixing that and installing a new fuel pump, I'm still under 600.00 on my investment. Here's the problem and it doesn't do this all the time, one day it might knock by the next it won't. I've scanned it, no codes! I'm baffled, any and all help would be great. Thank you
  #2 (permalink)
Old 11-12-2012, 10:01 PM
stevenn1's Avatar
stevenn1 stevenn1 is offline
stevenn1 is starting off with a positive reputation.
A bad Engine Knock Sensor?
  #3 (permalink)
Old 11-28-2012, 02:38 PM
BlueOvalFitter's Avatar
BlueOvalFitter BlueOvalFitter is offline
BlueOvalFitter is gaining momentum as a positive member of FTE.
Question
Sorry to hear about your situation.I'm in the same boat.After 30 years working as a pipefitter/welder I have been disabled almost a year now.
Is the knock like a "bearing" knock,as if it is not getting enough oil,or a "pinging" like knock,upon acceleration?
__________________
2007XL R/Cab,4.2 V6,auto,cruise control
The anticipation of death is worse then death itself!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
