R-22- R134
R-22- R134
I recently the AC in my '91 F-250 converted to R134. The shop removed all the R12 and recharged with R134 without running a cleaner through the system. I got about 1.200 miles from home when the compessor froze up. The shop that replaced it said that there should have been a cleaner ran through the system before recharging with the new refrigerant because the oil in the two refrigerants are not compatible causing the compressor to fail. The first shop denied this. I would like to know if I was misinformed, thanks.
I recently the AC in my '91 F-250 converted to R134. The shop removed all the R22 and recharged with R134 without running a cleaner through the system. I got about 1.200 miles from home when the compessor froze up. The shop that replaced it said that there should have been a cleaner ran through the system before recharging with the new refrigerant because the oil in the two refrigerants are not compatible causing the compressor to fail. The first shop denied this. I would like to know if I was misinformed, thanks.
Ester oil is compatible with either one but personally I do not like converting a R12 system over to R134a. Too many pitfalls that can bite you.
The other part of this story is asking if the system was working before you had the shop convert to R134a? Was the system ever open to the atmosphere for any length of time? There could be other factors leading up to this failure, but should have been addressed by the original shop the first time around.
There is a phrase for this : "A series of unfortunate events"
I am not trying to be a butthead, just pointing out there has to be more to the story here. This all adds up to one thing, half-a**ed A/C conversions are full of pitfalls. You were misled by the first shop. To their defense you should have read up more on what is suggested in order to have a successful conversion. An informed consumer is the best defense.
Take my comments and opinions for what they are worth, the cost was free.
When I changed the reciever drier there was no pressure so someone else may have had the system open at one time, also I didn't find an O-ring on one of the fittings. I just told you the sequence of events, when I took it in after changing the reciever drier they drew out anything that was left before charging the system with R134. They did not run any cleaner through it.
A real conversion should include the replacement of EVERY o-ring in the system with HNBR o-rings (the green ones). If they didn't flush the system they screwed you up.
This should be very informative:
http://www.sanden.com/originals/images/retro.pdf
ar1953
21
08-08-2008 09:36 AM
Rob88
03-28-2000 11:15 AM
