Flathead fan hub rebuild parts - Ford Truck Enthusiasts Forums
Old 11-09-2012, 11:01 PM
aussiecowboy aussiecowboy is offline
aussiecowboy is gaining momentum as a positive member of FTE.aussiecowboy is gaining momentum as a positive member of FTE.
The fan hub on my 49 fllathead is on the way out. I filled it with oil a while back according to procedure and the oil just ran out of the back at the shaft. Where can I buy the parts required for a rebuild? I haven't been able to find them anywhere. The cost of shipping kinda rules out buying an exchange unit, buy the time I pay the core charge and shipping it would be a $400 hub.
Old 11-10-2012, 12:28 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
VanPelt's website lists 21A-8626 Fan Spindle Bearing for $21. http://www.vanpeltsales.com/FH_web/e...prices-pg4.htm
Old 11-10-2012, 12:35 AM
Does this have the bearings inside it Ross? I thought there were press in oilite bearings that need to be changed. I have to admit, I've yet to pull apart to see, want the bits on hand to rebuild it when I do.
Old 11-10-2012, 12:38 AM
ALBUQ F-1's Avatar
postin' fool
I always heard they were oilite, but it appears they are either already pressed in, or it runs cast iron directly.
Old 11-10-2012, 12:52 AM
Interesting, I guess I really need to know if my shaft is ok.
Old 11-10-2012, 10:07 PM
bmoran4's Avatar
bmoran4 bmoran4 is offline
bmoran4 is gaining momentum as a positive member of FTE.
If you need C&G sells a complete hub.
https://secure435.hostgator.com/~dlv...epart=21A-8604
Old 11-11-2012, 12:22 AM
Yep, that's the one that would end up costing me almost $400 once I got it landed in Aus. I'll buy a new shaft and new spindle and have a go at mine I think, should cost only about $100.
Old 11-11-2012, 10:07 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
21A-8603 .. Fan Hub & Pulley Assy 239 V8 / Obsolete
1942/48 Ford/Merc Passenger Cars / 1942/52 all trucks.
JST AUTOMOTIVE in Lebanon TN has 2 = 615-443-3086.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 25 = 800-476-9653 / 704-786-8139.
Old 11-11-2012, 02:46 PM
Thanks for that Bill, I'll contact Carpenters and see what they are charging. For some reason I can't access their online catalogue.
Old 11-11-2012, 04:49 PM
ALBUQ F-1's Avatar
postin' fool
I can call them Tuesday, all their NOS stuff is "Call for Pricing". I got into their NOS site, and I don't see any.
Old 11-11-2012, 05:17 PM
That would be great Ross, I have sent them an email in the mean time.
Old 11-11-2012, 05:36 PM
oldmerc's Avatar
oldmerc oldmerc is offline
oldmerc
oldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to all
If it were me in your position of (cost of shipping takes the fun out of this )position . I would see if a machine shop can bore out the hub and press in a new bushing , ream it to fit and maybe even cut out a recess for a lip seal while their at it . Just a thought .
Old 11-12-2012, 02:09 AM
Quote:
PartsVoice.com = JST's 2 are listed there as are DC's 25.
Old 11-12-2012, 11:21 AM
fixnair's Avatar
fixnair fixnair is offline
fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.
Do not fill with oiul & let it go at that. There is no efective seal at the back end of the shaft, only a dust seal. You would want to do this proceedure about every 500 miles.
Here is what the factory said at the time.
"Turn the fan pulley with the screw on top. Remove the screw, fill with engine oil let set for a few minutes, now turn the pulley with the hole downwards let the excess oil drip out".
Now turn the pulley right side up replace screw and you done lubricating it.
Old 11-12-2012, 01:39 PM
Yep, exactly what I did. There appears to be enough wear present that it can't hold even that amount of oil.
Re doing my F350 navistardiesel 1999 to 2016 Super Duty 5 10-03-2015 11:43 PM
Oil Cooler and Dipstick Rebuild PICS PowerstrokeRyan 1994.5 - 1997 7.3L Power Stroke Diesel 16 01-22-2012 10:44 AM
Auto to Manual Locking Hubs - 1994 Explorer Ace! Explorer, Sport Trac, Mountaineer & Aviator 1 01-25-2009 12:50 AM
Help finding hub oilers online! Flywest Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing 14 12-10-2006 03:48 PM
51 F1 239 V8 - Fan Hub Exploded Illustration Available? arttruck 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 07-29-2002 10:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
