7 mpg??
7 mpg??
Alright, let's get this right out of the way right up front. I realize I own a big, heavy 1-ton truck with 10 hungry mouths to feed under the hood. Thus, I'm not expecting miraculous mileage. But based on what I've read on here, it seems my mileage is sub-par. So I'm gonna ask for some guidance.
I took the ATVs into the woods last weekend -- probably the last trip I'll get this year, as there was already 10+ inches of snow on the road at the highest elevations. I was pulling a small NON-enclosed trailer with 2 quads. Total weight: about 2500lbs. And I reported 7mpg. I was stunned...in a bad way. I've heard of guys on here getting 7mpg, but it's usually been pulling 8k, 10k, maybe 12k pounds. This was <3000lbs. I'm very nervous about what kind of mileage I'm going to be getting next summer with the 4000# camper in the bed AND the ATV trailer in tow.
In town lately, I'm getting ~10mpg. I normally drive 40-50mph with few stop signs or stop lights, and I drive with OD locked out. I kinda expect more than 10mpg given these conditions. And on the freeway, running 70-75mph, I'm not much better than 10-11mpg. Again, based on others' feedback here, seems I should be getting better.
The truck is totally stock. It's not throwing any codes, and seems to run and idle perfectly. No misses or anything like that. I will say that first thing in the morning, the exhaust smells like it's running very rich. But I think that's probably typical of early morning starts around here, especially since the weather turned cooler.
Truck has a new air filter, new fuel filter, and I just cleaned the MAF sensor a couple of weeks ago.
What are some of the items I should go after next?
Without more info on the truck I can't accurately give you info. Tire size, gear, chassis configuration, and weather play a factor. Although everyone else sees up to 14 highway, my average is right around 10.2 driving 60% highway at 60. I run slightly larger tires, have 4.10s, 4x4 CCSB. You said snow and spinning and slipping around is gonna net worse fuel mileage also. Plus I have a 3v which generally has a lower mpg rating than the 2v
Your signature says your running 285/75/16 tires (32.8 dia) but stock is 265/75/16 tires (31.6 dia) that changes your final gear ratio and if your computer was not changed to that tire size your odometer will be off so your mileage calculation is off. Also pull all your wells and check the slide pins on all the calipers to make sure they are moving freely, dragging brakes will kill gas mileage.
Denny
Denny
What was your procedure for cleaning the injectors with Seafoam? Did you just add a bottle to a tank of gas, or did you use a method that's more potent/concentrated?
I would've been ecstatic with 10mpg at 60mph with the camper loaded. Based on last weekend's experience, I'm fearing it'll be half of that. With my current setup, anyway. I'm planning on swapping spark plugs and a can of Seafoam to start with to see if that improves things any.
I have long-term plans for 4.56 axles and a 5-star tuner. This beast is going to be a towing/hauling vehicle, so I may as well set it up for those duties accordingly.
Ooh, good call on the ethanol. I know for a fact that the station I filled at on my way out of town has 10% ethanol mixed (stupid gov't mandates...). There are stations near me that sell 100% petro, though. I'll give that a shot and see what improvement, if any, I observe.
I spent some time Google'ing this morning regarding ethanol blended gasoline.
While the EPA reports that only a 3% reduction should be expected with E10 (what the heck do they know, though, right?), most of the actual reports I've seen is that a reduction of at least 10% is to be expected.
Being the engineer that I am, sounds like a controlled experiment is in order!
Going with a 5Star tune may be your best bet, it sure helped my truck get 1 mpg more.
I get 9.2 towing a 9K 5th wheel.
11.5 average empty
Just made a return trip from So Cal and got 14.7 mpg. (empty) My overhead monitor still reads 14.5.
