GOVTMOD's dumb electrical question of the day; solenoid "I" post as power source? - Ford Truck Enthusiasts Forums
Old 11-09-2012, 09:49 PM
GOVTMOD GOVTMOD is offline
GOVTMOD is gaining momentum as a positive member of FTE.GOVTMOD is gaining momentum as a positive member of FTE.
I'm putting a power control box in my truck with a key on relay.
I figured it would be OK to hook up the relay to the "I" post of the solenoid. The box is going pretty much where the solenoid is right now and I'll in turn be relocating that down the fender shirt but it will still be right there.
I just wanted to check if there would be any issues. If there are, where would be the best place to hook it up? I'd rather not have to run it all the way from the ignition switch.
Old 11-09-2012, 09:58 PM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
Maybe time for my dumb question, what is a "power control box?" not familiar with this term.
Old 11-09-2012, 10:02 PM
Quote:
Under hood fuse and relay box, most new vehicle have them. Some don't have in cabin fuse boxes anymore.
Old 11-09-2012, 10:04 PM
Oh. My solenoid only has 3 wires, it has battery in, starter out, and the ignition that runs to it from the switch. So there would be no appropriate connection there for a relay switch that was turned on by the switch, as its only hot when the ignition is turned forward to start.
Old 11-09-2012, 10:11 PM
HIO Silver's Avatar
HIO Silver HIO Silver is offline
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Quote:
More often than not newer vehicles have two... one in the cab and one under the hood.
So, I understand you want to run a signal wire to the "I" post of the starter solenoid to engage the relay (a continuous duty solenoid) of the power distribution box, right? It'll work.
Old 11-09-2012, 10:18 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Does it need to be constant hot with the ignition on or just hot in "start"?
The "I" terminal is only hot when the key is in the "start" position.
Old 11-09-2012, 10:30 PM
Hot only when key is on. Which I thought the "I" was. I'm putting in a MK VIII fan and I'll be running the temp switch ground through it. Since I'm putting some headlight relays right next to it I figured I'd hook them up through it too.
Do you think it'll need to be fused?
Old 11-09-2012, 10:54 PM
HIO Silver's Avatar
Isn't the I terminal electrically the same as the + post on the coil???
The S terminal is for "Start" and is energized by the ignition switch.... Or am I reading these schematics incorrectly?
Old 11-09-2012, 11:43 PM
Neek Neek is offline
Neek is starting off with a positive reputation.
Hello GOVTMOD,
Yes, the fan and headlights relays need to be fused.
Hello HIO Silver,
Yes, the 'I' terminal can be connected directly to the + post on the coil, and will only have current at start up.
This connection is for ignition systems with ballast resistors, or resistor wire, whereby the voltage to the coil is +/- 9 volts, but at start up, the coil needs +/- 12 volts.
Old 11-09-2012, 11:45 PM
co425's Avatar
co425 co425 is offline
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
Yes the "I" post should work fine. There is only a very small electrical requirement to trip a relay. I would fuse it just to be safe. A short there would probably fry your ignition switch wiring as well as the coil wiring. No fun.
Old 11-10-2012, 05:52 AM
Canus Canus is online now
Canus is starting off with a positive reputation.
If you need power with the key in the ON position the connection to the "I" terminal WILL NOT work!! The "I" terminal ONLY sees power with the switch in the START position. You will need to find another "keyed on" source.
Old 11-10-2012, 09:44 AM
Quote:
Thats not true, unless its a latching relay, a standard automotive relay requires current to stay on to keep the relay switched.
Old 11-10-2012, 10:38 AM
You guys aren't going to make me go out and check myself are you? There's like 6" of snow out there, no joke and it's not letting up. No room in the garage either.
Seriously, I do appreciate the input even if it is contradictory. I do know that I don't have to have a full 12v to run the relay as I've actually been testing them with a 9v battery. The terminals are spaced perfectly for 85 & 86. I do need to find out if it is actually hot with the key at "on" and whether it will cause problems anywhere else if I borrow the current.
Old 11-10-2012, 10:59 AM
mikeo0o0o0's Avatar
That sucks about the snow, glad I'm in Fla.
The "I" terminal on the starter solenoid is hot ONLY when the key is in the start position. It is dead when the key is in run.
The "I" terminal shoots a full 12V to the coil when starting. When you release the key and it returns to the run position the "I" terminal will be dead.
If you need a constant 12v source when the key is in the run position, the "I" terminal will not work.
EDIT: Thinking about it . The "I" terminal will have voltage to it when the key is released but I wouldn't recomend using it as a power tap.
When you release the key the circuit inside the solenoid opens and stops feeding 12v to the coil, BUT the circuit will now backfeed FROM the coil. It will only be ~6-7 volts though AND it will place an additional load on the ignition circuit, something that generally isn't desired as it could lead to mis-fire or other ignition problems .
Old 11-10-2012, 12:07 PM
OK the plot thickens, I can't think of anything else under the hood that is key on only. I guess I'll run a line from in the cab. No biggie I'm going to have run some other wires from the cab I'll just add that one to the list.
HELP!!! BlaineFrick 1999 to 2016 Super Duty 3 05-01-2016 07:56 AM
**TRADED**1979 Ford F-150 4X4 Short bed 400 4 Spd + extras GOVTMOD Vehicles for Sale 4 03-14-2015 10:49 PM
Help! Dead Excursion (no interior electrical) stumppullerny Excursion - King of SUVs 3 03-07-2015 05:20 PM
Taurus power box install help. GOVTMOD Electrical Systems/Wiring 22 08-04-2013 06:19 PM
F-350 utility box steal!!! GOVTMOD 1973 - 1979 F-100 & Larger F-Series Trucks 0 05-10-2013 07:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
