Well time for new batteries - Ford Truck Enthusiasts Forums
Old 11-09-2012, 09:53 AM
JonArmy JonArmy is offline
JonArmy is starting off with a positive reputation.
Well as the topic states it's time for me to get new batteries for the truck. Well I know that some topics have talked about what type battery to get, well I'm planning on getting Duralast/Battery (65-DL) | 2004 Ford F350 Super Duty P/U 4WD 8 Cylinders P 6.0L Turbo Diesel | AutoZone.com from AutoZone
Yes I know that some people have issues with AutoZone parts, but I feel that right now this would be a good option.
When I get them I plan on changing the passenger side first then drivers side.
The reason I feel I need batteries, this morning at ambient was 30, cycled the key a few times for the glow plugs to fully warm up and get stuff ready. I had my AE connected and monitored battery voltage and it droped all the way down to 8 volts, it was iffy at first start up then the second time it cranked and held around 12v while the glow plugs were still on before the alternator kicked in. When the alternator kicked in the voltage stayed around 12.5 to 13.5v
I had load tested my batteries with my handheld one by one not connected to each other and not run for the day and that was during summer and everything was good, but with the temp dropping low and more time with glow plugs and so I don't screw the FICM I want to change the batteries to confirm and if later a alternator is bad then it will get changed, worse case would be the FICM sent to Ed.
Old 11-09-2012, 10:04 AM
the_auto_tech's Avatar
the_auto_tech the_auto_tech is offline
the_auto_tech has a good reputation on FTE.the_auto_tech has a good reputation on FTE.the_auto_tech has a good reputation on FTE.
I would go to Wal-Mart and pick up the Everstart Maxx 850CCA batteries. 99 dollars a piece, 3 year free replacement, and made by Johnson Controls plus there's always a ton in stock.
Old 11-09-2012, 10:23 AM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
I bought to AutoZone Batterys the Step up from whay your looking at they were the 850CCA ones
They had a 8 year warrenty with the 3 year Free replacement
Well 3 weeks Shy of the 3 year free replacement I notice they were struggling so I replaced them for free
1 Battery had a Bad Cell the Other Battery had a Cell I could see going bad Hydro testing
So AZ Did replace Both at that time But IMO 3 Years Isnt the Best
I think there are better Options out there
Will see how these New Batterys Hold Up but If they Die again within 4 Years I will be Looking for a Better Option maybe I am Expecting to much from Batterys IDK this Diesel does Work them Pretty Good at each startup
Old 11-09-2012, 10:36 AM
Rusty Axlerod's Avatar
Rusty Axlerod Rusty Axlerod is offline
Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.
Everybody's got their opinion I guess but I've had good luck with the AZ batteries. I have a pair of Duralast gold tops in now and expect good service from them. (Hope I didn't just jinx it )
Old 11-09-2012, 10:45 AM
mustang_309's Avatar
mustang_309 mustang_309 is offline
mustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to behold
[quote=JonArmy;12466529]Well as the topic states it's time for me to get new batteries for the truck. Well I know that some topics have talked about what type battery to get, well I'm planning on getting Duralast/Battery (65-DL) | 2004 Ford F350 Super Duty P/U 4WD 8 Cylinders P 6.0L Turbo Diesel | AutoZone.com from AutoZone
I had load tested my batteries with my handheld one by one not connected to each other and not run for the day and that was during summer and everything was good, but with the temp dropping low and more time with glow plugs and so I don't screw the FICM I want to change the batteries to confirm and if later a alternator is bad then it will get changed, worse case would be the FICM sent to Ed.[/quot
So you cycled through 3 full glow plug cycles before starting the truck? That cant be good for the batteries, just on one cycle it drags my batteries down in the 11's. I think plugging in the block heater and starting after the glow plug pigtail lights go out should be more than enough.
Old 11-09-2012, 10:46 AM
CPB1's Avatar
CPB1 CPB1 is offline
CPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to behold
I just put in 2 new batteries. Everstart Maxx from Wal-Mart. The first thing I noticed is how bright the inside lights are now. Big difference. We will see how long they last. They replaced 2 Motorcraft 750cc amp batteries with a date code of 2008. So 4 years is the norm for batteries on these trucks?
Chuck
Old 11-09-2012, 10:55 AM
Misky6.0's Avatar
Misky6.0 Misky6.0 is offline
Misky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputation
I splurged on Sears Platinums when they were on-sale last month with
an additional $40 on-line coupon (ended up at $174 each).
Engine cranks a LOT faster and my voltage stays nice during
engine warm up.
They have 4 year free replacement, 100 month pro-rated replacement.
Old 11-09-2012, 11:08 AM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
No need to cycle the glow plugs more than once for anything above -10 degrees.
Josh
Old 11-09-2012, 11:12 AM
BLADE35's Avatar
Quote:
Same ones I have^^^
I will add that I had a Alternator go out little over a Year ago but caught it before things went to bad
Since then I have had a DC Power 190amp Alternator keeping them charged now
Wish we could get the same batterys that the Trucks rolled out the assembly plant with
I got 6 years out the OEM Batterys I dont think the Replacement OEM Batterys are the same IDK
Old 11-09-2012, 11:37 AM
Crash16 Crash16 is offline
Crash16 is gaining momentum as a positive member of FTE.
I'm running napa's brand. 110 per battery with 6 year warranty.
Old 11-09-2012, 12:34 PM
Well I finally just went to AutoZone and got the 850cc Duralast. Didn't take me long, but keeping on my battery voltage and FICM with my edge and battery never drops below 13.5 and if it does it's only for around 10 seconds. The FICM stays at 48.0 it's only dropped to 47.5, before battery change it was dropping to around 46.5. Well I'll find out in the morning how well she runs. I might still change the alternator soon probably to the DC generator system. With the FICM looking good I'll still keep a eye on it, I might splurge and get the Bullet Proof Diesel FICM and keep at 48 v since I've heard it has better heat displacement and that's another thing that can kill the FICM.
Thanks for all the suggestions
Old 11-09-2012, 01:48 PM
MC5C MC5C is offline
MC5C has a very good reputation on FTE.MC5C has a very good reputation on FTE.MC5C has a very good reputation on FTE.
The alternator is actually on as soon as the engine starts, which is why in your case the voltage got up to 12 as soon as the engine started - the batteries sure weren't going to jump up just because the engine was running when the glow plugs were still on. It is clear that new batteries are needed, with that low initial voltage reading, so you are doing the right thing there. Cycling the glow plugs several times is not only a bad thing to do for your batteries, it doesn't do anything to help a start - remember that the glow plugs stay on for several minutes anyway, after the light goes out, and as soon as the glow plug is hot enough to fire the cylinder, it doesn't need more time. Keeping the glow plugs lit for a long time is not a starting aid, it's to reduce emissions while the engine is being over-fueled while it's still cold. My advice is don't do that any more, your batteries, FICM and injectors will all thank you with longer and better service.
Brian
Old 11-09-2012, 03:18 PM
Rovernut's Avatar
Rovernut Rovernut is offline
Rovernut is gaining momentum as a positive member of FTE.Rovernut is gaining momentum as a positive member of FTE.
Quote:
Sounds like your alternator is bad. Your high reading is below the correct low voltage output for an alternator. Should be 13.8 to 14.2. Though it's possible your low batteries are so shot the alternator isn't performing properly.
But don't wait to test your alternator once you get new batteries, otherwise you'll kill your new batteries too.
Here's a good guide to testing your alternator:
http://www.prestolite.com/literature...leshooting.pdf
Old 11-09-2012, 03:37 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
....and ALWAYS replace your batteries in PAIRS!
Old 11-09-2012, 04:15 PM
Bullitt390's Avatar
Keep in mind some are taking readings at the battery and others are taking it with a reader/scanner at the OBD port.
Expect about .2-.4 volts LOWER at the port versus the battery.
I agree charging voltage should be 13.8-14.6 volts at the batteries.
In most cases, at operating temps I see 13.6-14.1 volts at the port.
Josh
Batteries Rusty Axlerod 6.0L Power Stroke Diesel 16 03-07-2015 06:37 PM
Duralast Platinum batteries any good? djousma 6.7L Power Stroke Diesel 4 03-31-2014 07:13 PM
Rerouting alternator main cable 78fordman 6.0L Power Stroke Diesel 10 01-03-2014 12:02 AM
Do i have a voltage issue? bigred66 6.0L Power Stroke Diesel 21 01-21-2013 09:51 PM
Cold Weather Sputter BobbyB 6.0L Power Stroke Diesel 2 10-08-2010 07:43 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
