80-86 Front ttb fit 95 F150?
I am currently building a 95 F150. I am planning on putting 4.11's in the front and rear soon after I put the 6" lift and wheels and tires on I got for it. But I was searching thru my local craigslist tonight and found a guy parting out a 82 or 83 Bronco, front D44 TTB has gears and an air locker installed on it, I could pick it all up for a fair price, but was wondering if the beams work on a 95? I know the newer stuff has the ABS system, can I swap the stuff to the older beams (think the knuckles just have to be swaps maybe?). Anyone know if they work?
LMC shows the passengers side beam is the same from 80-96, it shows the drivers side being from 87-96. 45-0950 is the part number, you might call and ask if it would fit on that year Bronco. But aside from small differences in knuckles and other small parts, considering the spring & shock towers and some other parts I checked real quick are also the same 80-96 I doubt there would be much difference.
Sorry its not much, but its a start.
EDIT: I just went and checked JBG and they list the same TTB arms from 80-96, both drivers and passengers side so I'm sure you'll be fine to do your swap. Now as to if you can swap your ABS stuff on, that I have no clue about.
curry69
03-10-2004 12:31 PM
