Buying a 96 F250 Crew Cab 7.3 4x4 any advice?
Old 11-09-2012, 05:23 PM
tshrager's Avatar
tshrager
tshrager is offline
Originally Posted by dcase13
Wow, thats awesome. And don't worry I will get a pic to you guys as soon as I get the keys!
Yessir, stick with FTE and learn as much as you can. These guys won't steer you wrong.
  #32
Old 11-09-2012, 05:26 PM
dcase13's Avatar
dcase13
dcase13 is offline
I am seeing that! I am excited to learn as much as I can about the 7.3.
  #33
Old 11-09-2012, 05:41 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
Great to hear you got a new truck! Gotta see more pics for sure!
  #34
Old 11-09-2012, 06:39 PM
fordman67's Avatar
fordman67
fordman67 is offline
Awesome! Yet another CC!
  #35
Old 11-09-2012, 11:03 PM
dcase13's Avatar
dcase13
dcase13 is offline
Ok so now that its settled, any advice on getting rid of the red interior haha
  #36
Old 11-09-2012, 11:22 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Update: I am going to go get it Monday, would of today but work got in the way. Pretty excited about it, only thing I am going to be nervous about is the injectors as the current owner doesn't know when or if they have ever been replaced but has always changed the oil every 5k along with the fuel filter every 10k. I talked to our diesel specialist here and he said worst case is down the road 3K for injectors to be replaced. It doesnt smoke on cold start, and starts right up without any shaking or funny noises. Non the less I can't wait to call her mine!
Congrats on getting the truck!.........I knew you would LOL!!
  #37
Old 11-09-2012, 11:46 PM
FI460's Avatar
FI460
FI460 is offline
I would find a donor truck with the color you want and use what you can from there. Should be able to find a nice gasser parts truck.
  #38
Old 11-10-2012, 05:38 AM
427 fordman
IMO let the red grow on you. You're gonna have a hard time finding all the stuff you need, especially being a 4 door, to switch it over, not mentioning all the work.
  #39
Old 11-10-2012, 12:54 PM
dcase13's Avatar
dcase13
dcase13 is offline
I think I might just get seat covers for the front and back and call it good, as it is in great condition...and I know I am going to want to start some mods on the motor, its all stock right now has new exhaust but is just single 3inch , I want to do the exhaust 4inch turbo back with a 5 inch tip, but have no idea where to start with the motor. Chip? Fuel Plate?
  #40
Old 11-10-2012, 01:01 PM
glovemeister's Avatar
glovemeister
glovemeister is offline
These don't require fuel plates, that is a Cummins thing IIRC.
You need:
3 inch downpipe with your exhaust mods,
6637 intake,
boost and egt gauges so you don't melt down your motor
After that there is always:
Electric fuel
Bigger Turbo
Bigger Injectors
Built auto or SMF conversion and built clutch if 5spd.
  #41
Old 11-10-2012, 01:19 PM
dcase13's Avatar
dcase13
dcase13 is offline
You need:
6637 intake,
Electric fuel
Bigger Turbo
Bigger Injectors
Good to know thanks! Is there an oil you recommend for the motor, transfercase, and diffs? With 270k should I run a synthetic blend?
  #42
Old 11-11-2012, 06:49 PM
fordman67's Avatar
fordman67
Diff yes syn.trans and case yea.engine,that is a personal choice.just depends on who you talk to.
  #43
Old 11-11-2012, 07:46 PM
fordpride's Avatar
fordpride
fordpride is offline
If you have any oil leaks fix them be for you run synthetic. They will leak faster with synthetic
  #44
Old 11-11-2012, 07:48 PM
glovemeister
I run a 15w40 Shell Rotella, Delo is also quite fine in the same viscosity. I am gonna try a 5w40 for this winter though I think. I run a synthetic atf in my zf5 trans, I run any 80w90 in my diffs, t case I haven't changed.
  #45
Old 11-11-2012, 07:57 PM
FI460's Avatar
FI460
FI460 is offline
I run Delo 15/40. Walmart in Medford had it on sale last week. Havent changed my diff's since I bought the truck yet.
Quick Reply: Buying a 96 F250 Crew Cab 7.3 4x4 any advice?
