Buying a 96 F250 Crew Cab 7.3 4x4 any advice? - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 11-09-2012, 05:23 PM
tshrager's Avatar
tshrager tshrager is online now
tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.
Quote:
Originally Posted by dcase13 View Post
Wow, thats awesome. And don't worry I will get a pic to you guys as soon as I get the keys!
Yessir, stick with FTE and learn as much as you can. These guys won't steer you wrong.
  #32
Old 11-09-2012, 05:26 PM
dcase13 dcase13 is offline
dcase13 is starting off with a positive reputation.
Quote:
I am seeing that! I am excited to learn as much as I can about the 7.3.
  #33
Old 11-09-2012, 05:41 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Great to hear you got a new truck! Gotta see more pics for sure!
  #34
Old 11-09-2012, 06:39 PM
fordman67's Avatar
fordman67 fordman67 is online now
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
Awesome! Yet another CC!
  #35
Old 11-09-2012, 11:03 PM
Ok so now that its settled, any advice on getting rid of the red interior haha
  #36
Old 11-09-2012, 11:22 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Update: I am going to go get it Monday, would of today but work got in the way. Pretty excited about it, only thing I am going to be nervous about is the injectors as the current owner doesn't know when or if they have ever been replaced but has always changed the oil every 5k along with the fuel filter every 10k. I talked to our diesel specialist here and he said worst case is down the road 3K for injectors to be replaced. It doesnt smoke on cold start, and starts right up without any shaking or funny noises. Non the less I can't wait to call her mine!
Congrats on getting the truck!.........I knew you would LOL!!
  #37
Old 11-09-2012, 11:46 PM
FI460's Avatar
FI460 FI460 is offline
FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.
I would find a donor truck with the color you want and use what you can from there. Should be able to find a nice gasser parts truck.
  #38
Old 11-10-2012, 05:38 AM
IMO let the red grow on you. You're gonna have a hard time finding all the stuff you need, especially being a 4 door, to switch it over, not mentioning all the work.
  #39
Old 11-10-2012, 12:54 PM
Quote:
I think I might just get seat covers for the front and back and call it good, as it is in great condition...and I know I am going to want to start some mods on the motor, its all stock right now has new exhaust but is just single 3inch , I want to do the exhaust 4inch turbo back with a 5 inch tip, but have no idea where to start with the motor. Chip? Fuel Plate?
  #40
Old 11-10-2012, 01:01 PM
glovemeister glovemeister is offline
glovemeister is gaining momentum as a positive member of FTE.glovemeister is gaining momentum as a positive member of FTE.
These don't require fuel plates, that is a Cummins thing IIRC.
You need:
3 inch downpipe with your exhaust mods,
6637 intake,
boost and egt gauges so you don't melt down your motor
After that there is always:
Electric fuel
Bigger Turbo
Bigger Injectors
Built auto or SMF conversion and built clutch if 5spd.
  #41
Old 11-10-2012, 01:19 PM
Quote:
You need:
6637 intake,
Electric fuel
Bigger Turbo
Bigger Injectors
Good to know thanks! Is there an oil you recommend for the motor, transfercase, and diffs? With 270k should I run a synthetic blend?
  #42
Old 11-11-2012, 06:49 PM
fordman67's Avatar
Diff yes syn.trans and case yea.engine,that is a personal choice.just depends on who you talk to.
  #43
Old 11-11-2012, 07:46 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
If you have any oil leaks fix them be for you run synthetic. They will leak faster with synthetic
  #44
Old 11-11-2012, 07:48 PM
I run a 15w40 Shell Rotella, Delo is also quite fine in the same viscosity. I am gonna try a 5w40 for this winter though I think. I run a synthetic atf in my zf5 trans, I run any 80w90 in my diffs, t case I haven't changed.
  #45
Old 11-11-2012, 07:57 PM
FI460's Avatar
I run Delo 15/40. Walmart in Medford had it on sale last week. Havent changed my diff's since I bought the truck yet.
96-97 Extended cab question husky390 1994.5 - 1997 7.3L Power Stroke Diesel 23 01-08-2015 04:15 PM
02 7.3 in a 96 f250 crew gasser? DanielT28 1994.5 - 1997 7.3L Power Stroke Diesel 19 07-29-2014 08:15 PM
What MPG can I expect on a 1997 Ford F250 4x4 Crew Cab RickTFL 1994.5 - 1997 7.3L Power Stroke Diesel 5 07-08-2014 08:05 AM
76 crew cab w/ 7.3 L powerstroke??? Montana Made 1973 - 1979 F-100 & Larger F-Series Trucks 10 07-30-2012 08:44 PM
No Wastegate on the turbo??? PwrStroke7.3 1994.5 - 1997 7.3L Power Stroke Diesel 2 10-09-2006 10:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
