You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
since cetane rating is how readily the fuel ignites, i suspect the straight diesel would be better in that regard. but i'm no scientist when it comes to this.
i've run as much as 20% oil in my diesel with good results, i would say you're totally fine running even a few gallons oil per tank of fuel, though i can't say what it does to the cetane rating. but if it runs well on it, what does it matter
I try to burn B100, from Houston BioDiesel whenever I can, and have since Y2K or thereabouts; I'll never forget just how much the 12V BTA 5.9 smoothed out when the petrodiesel segued to the Bdiesel at the combustion chambers; night and day difference!
I asked HBD's owner (and pump jockey/cashier/warehouseman/buyer/salesman/class instructor/etc., you get the picture) about this phenomenon, and FWIW, he told me Bdiesel has not only higher lubricity values, but B100 has a cetane rating around 65+-, whereas USA-spec petroleum diesel runs 54 (the lowest in the world, BTW). Perhaps exaggerated slightly (c'mon--11 points?), but considering the improvement in engine performance I saw, I have no real reason to doubt him.
Eddie, The
Reason: Used "'s" when I should'ha used "s'"
Diesel is a distillate and is measured in cetane. WMO is a residual and cannot be measured in cetane levels, but should be measured CCAI or CII, in IMO. In reading, the calculation will normally give a value somewhere between 800 and 880. The lower the value is the better the ignition quality. Fuels with a CCAI higher than 880 are often problematic or even unusable in a diesel engine. CCAI are often calculated under testing of marine fuel.
So I think the question people should be asking is what is the CCAI of WMO?
So, does anyone have a number?
Note, all info above was from Wiki searching cetane.
Eddie, The
On my usually traveled route which includes NY, PA, OH, NC, WV, and VA, I have seen several diesel pumps with stickers indicating their diesel cetane rating is 40-45. I think the minimum must be 40 since I've never seen it lower than that. I would love it if the min spec was 54, the highest I've seen is 50 on a few premium diesel pumps.
As far as us being the lowest in the world, I lived in eastern Africa for 2 years and can undoubtedly tell you that their diesel isn't nearly as good as ours. I don't have any hard numbers but I know of several fuel stations that in no way, shape, or form, had a higher cetane rating than what we have in the US.
One thing to remember about cetane is every engine requires a different amount, and every engine has a sweet spot. It is possible to put in to much cetane and get a net loss of power. The cetane flashes off to soon in the injection cycle resulting in less power due to the advanced timing.
5 gallon's 0-20 moter oil, and 5 gallons diesel, 1/2 gallon rug, no differance in how she runs or starts, my oil is virgin,,I get it from work, some atf in the mix as well,, i try to get the light 0-20 oils...
__________________ Needed 3.73 limited slip Dana 60 rear end,1991,no vss,with anti loc.. Democracy is two wolves and a lamb voteing on what to have for lunch, Liberty is a well-Armed lamb contesting the vote. Benjamin Franklin... My Boy is a MARINE.... 72 F250 390 HI BOY 4speed.... 91 E350 7.3 idi
