D2TE-AA heads
D2TE-AA heads
Is there any kind of work that can be done to these heads to help them flow better and obviously make me more power? Just out of curiosity since I've been thinking of stuff to spend my money on next.
I just need to know if it's worth doing any work to these heads and if not then that's all.
If I were to build a 445 truck motor, I'd use these heads for sure.
Here is a set after a valve job and some port work:
http://www.network54.com/Forum/74182...Schmader+today
Oh they're just staying on my 390 which I believe is an 8:1 or so engine. I just wanted to know if there is anything that can be done to these heads that's worth spending the money one. Also do I need to take them to a FE person or can I just take them to anyone that can do the head work?
Would it be a good idea to have the intake runners port matched to the intake? I have a holley SD with a holley 750 on top. And headers for the exhaust.
It's stock except headers, Holley SD intake and a Holley 750. I called a local shop yesterday that delt with building FE's and he said that they don't use flat tappet cams anymore because of of how many failures that occur. He told me that I should look in to a set of edelbrock heads, which is why I asked if I can do any work to the stock heads instead. I have a comp 270h, but after what he told me, I think I will return it and save a grand for a hyd. roller set.
Another reason I wanted to consider having work done to the heads, is that 2-3 cylinders leave oil around the threads of the spark plugs, leaving me to believe that oil is leaking somewhere. I don't think it's bad rings cause the cylinder walls look good and that isn't any smoke from the exhuast at least from what I've ever noticed.
FossenRacing
08-09-2010 08:45 PM
sssilvernblack
04-10-2009 07:20 AM
Annihilator
10-06-2004 01:14 PM
Special ' 67
18
12-02-2003 09:29 PM
