Maybe A short?? Need some help
Old 11-08-2012, 06:21 PM
rcdude's Avatar
rcdude
rcdude is offline
Exclamation Maybe A short?? Need some help
New to the forum hope this in the right section.
So I'm having some problems with my 95 I6 f150. I swapped my cluster to a new one ( so I could get a tachometer) left the lights on killed the battery.
Recharged the battery over night died within the day, bad alternator.
Fixed alternator, tested at auto zone works, but still the battery dies in a day.
Only thing i can think of that could have caused this problem to arise is possibly a short. I grounded the starter when changing the temp sensor on the block the same day
Thanks for the help
Mike.
Old 11-08-2012, 07:00 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,153 Likes on 911 Posts
What model year cluster did you swap in? This is a very common problem. I think you need to use a 1994-95 cluster because of wiring differences in the clusters over the years. Using a newer or older version usually triggers this issue. I think subford has some info on this in the forum.
Post #14 in this thread: https://www.ford-trucks.com/forums/1...questions.html
Old 11-08-2012, 07:08 PM
rcdude's Avatar
rcdude
rcdude is offline
I got it form a junk yard, forgot the year. Everything works great on the cluster.
Do you think the new cluster could cause a problem with the alternator? It just seems it not recharging the battery thats the only problem I am having
Thanks for the help
Mike.
Old 11-08-2012, 07:25 PM
rla2005's Avatar
rla2005
Thanks for the help
Mike.
Yes the cluster could be causing your issue. The power for the alternator "exciter" supply comes from the ignition switch, through the instrument cluster (bulb and bypass resistor), then onto the alternator. The exciter wire, Light Green/Red, should always be hot when the key is in the On/Run position. This "exciter" signal tells the alternator to turn on.
I would start at the alternator to verify this signal is getting there, then work backwards from there.
Old 11-08-2012, 07:33 PM
rcdude's Avatar
rcdude
rcdude is offline
Alright so you think i should just swap my old cluster back in and see if it fixes the issue?
Old 11-09-2012, 11:23 AM
rcdude's Avatar
rcdude
rcdude is offline
BUmp
Anyone else have any ideas??
Old 11-09-2012, 12:00 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
I think this would be you best bet. if it clears the problem then you know you had one that was not compatible.. Then you can search for the proper one, you need to know what year it comes out of, junk yards will tell you they are all the same.... Sorry they are not!!!
Edit: This response was assuming you had done the simple test you were given back in post #4..
rla2005's Avatar
rla2005
It would be a lot quicker to meter the Light Green/Red wire going to the alternator as a first step.
dragford1
07-19-2019 09:56 PM
GRNMSTR
2004 - 2008 F150
06-04-2016 07:33 PM
Diesel's Mechanical
09-26-2011 08:18 PM
crazycobra1969
11-09-2008 12:25 PM
Machman
11-09-2004 08:02 PM
Quick Reply: Maybe A short?? Need some help
