Oil in Air Box
Oil in Air Box
I have a '93 F150 302 5.0 EFI that I recently got back on the road after being parked for about five years. When I got it back out to be my daily driver i replaced transmission, torque converter, all front end bushings, plugs, wires, cap and rotor, and changed the oil.
After the first thirty miles of driving I noticed a small amount of smoke coming from the left side of the hood so I stopped and found oil leaking from the air box. Initially I blamed it on an incorrect (non vented) oil cap that I had put on because mine went missing, so I got the correct cap on it and didn't notice new oil in the air box for about 150-200 miles. Now i'm about half a quart low on oil and there is cloudy aerated oil at the bottom of the air box again. It is coming out of the return hose that comes from the oil filler neck to the airbox.
Can anyone help me out with what might be causing this?
First thought is a bad PCV located on the passenger side valve cover, under the intake plenum. Once you verify it is good or replace it (Motorcraft only please) then you may need to do a compression check/leak down test if the problem persists.
The crankcase is getting pressurized by either a plugged PCV or excessive blow-by from the piston rings.
on
I opted to replace my engine with a used w/ only 60,000 on it when my piston rings went out earlier this year.
If it's still throwing out oil after the PCV replacement, as every poster in here already mentioned your piston rings are shot. You can switch to a cheaper and thicker oil (20w50) and run it like that for a while if it isn't loosing too much oil. As long as you keep the oil level under check you can run the truck undefinitely, but it will only get worse in time, the options to address this are the ones stated by Alex.
You can drive it, but you will eventually have, or maybe already have, a major lack of power. I couldn't believe how much more responsive the replacement 302 in my truck was after swapping out the old engine with bad piston rings. The old engine eventually couldn't even go over 60 mph. It would not budge any higher.
Skrappy- you have blow by from the worn rings and will need to eventually replace the rings/ rebuild the engine. However, if you want to put off the ring replacement/rebuild for a while and keep most of the oil out of the airbox/ intake tract, you can either buy or build an air oil separator. google it, there are several sites out there that will tell you how, basically you plumb the separator between the pcv valve and the intake manifold vaccuum source. the separator has filter media in it to capture most of the oil vapors. i did this to my 351 windsor in my 1990 f350, and was able to keep oil out of the intake manifold/ air filter box/ throttle body. just realize that your entire intake tract from the airbox to the intake valve is gonna be coated in oil.
