dana 44 swap?
dana 44 swap?
Hey Ive got a 74 f250 4x4 with the hd dana 44 in it. I dont intend to mud or wheel with it. just drive it and restore it. It has drum brakes closed nuckle and king pins. Its also a low pinion 44. I also have a dana 44 from a 78 f250 sitting should i swap to the 78 or leave it alone?
Sorry its been along time since my last post. been really busy building the truck I mud with. but I've been thinking personally I really like the closed knuckles on my truck. I've been thinking is there any way I can just change spindles and bolt on disc brake brackets off a 77 lp hd axle and still have my king pins and closed knuckles? would I have to modify the spindle to fit? Thanks.
Received 3,099 Likes
on
about the only thing closed knuckles are better for is semi-keeping crap out of ujoints and axle tubes, but it's not a wheeler and all of the other bad points of that axle make it a moot point. the only possible issue i could see is driveshaft interference going to a hp axle in a stock divorced case truck, but i have very limited experience with highboys, letalone stock height, unmodified ones....
plus parts for those axles have to be hard as hell to come by if something wears out or breaks. you can still find full parts support just about anywhere for 77.5 trucks and up though.
I honestly I think they are cool. I like the big lock outs this one has and that my front u joints are protected. But like I said this isn't a mud truck and I don't do any serious off roading with it. I have a mud truck for all that.
on
the way i look at it, the front u-joints ARE NOT protected.
because those closed knuckles always leak, they also trap all kinds of crap inside which destroys stuff, and the drum brakes flat out suck for a heavy truck..
the 71 used to eat u-joints left and right because of the lousy felt seals.
after it got the open knuckle 44 with disc brakes, never replaced a u-joint again for the 14 years it was on the road.
well I just had the knuckles apart to do king pins and from the looks of it the u joints are original. my knuckles don't leak because they're mainly packed with grease. all I do is occasionally put it a touch of 80-90 gear just enough to slosh around. they're cool and you don't see them anymore... at least where I'm at.
goda123
24
01-03-2015 10:27 PM
MudinMan19704x4
01-24-2004 08:38 AM
