What are the volt readings on a new FICM. - Ford Truck Enthusiasts Forums
Old 11-08-2012, 01:45 PM
Will Bite's Avatar
Will Bite Will Bite is online now
Will Bite has a very good reputation on FTE.Will Bite has a very good reputation on FTE.Will Bite has a very good reputation on FTE.Will Bite has a very good reputation on FTE.
My FICM runs at 48v at start up but runs between 48v-46.5v when driving. Does this mean its on its way out. FLP power is at 13.5v and FVP power is at 13.5v. I just installed two new battery's last week.
Old 11-08-2012, 01:57 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is online now
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
48 is the standard, but the range is 45-49 volts.
Josh
Old 11-08-2012, 02:54 PM
Will Bite's Avatar
I guess im still in range then.
Old 11-08-2012, 03:29 PM
raptor131's Avatar
raptor131 raptor131 is offline
raptor131 has a great reputation on FTE.raptor131 has a great reputation on FTE.raptor131 has a great reputation on FTE.raptor131 has a great reputation on FTE.raptor131 has a great reputation on FTE.
Quote:
I got nervous and bought new one when it dropped below 43 , it tends to slowly only get worse.
Old 11-08-2012, 03:52 PM
Bullitt390's Avatar
Are using Torque or DashBoss to get the FICM readings?
Josh
Old 11-08-2012, 06:07 PM
Will Bite's Avatar
Torque app.
Old 11-08-2012, 09:46 PM
kidoo kidoo is offline
kidoo is starting off with a positive reputation.
At 30 degree today outside, FICM was reading 42 right after startup, then it raises to 46, 47 after glow plug do their job, then it plays between 45 to 47.5. I will check it again after it warms up.
Old 11-08-2012, 09:50 PM
Bullitt390's Avatar
Quote:
Anything below 45 is considered a failed FICM. I would say you are on borrowed time if you are seeing 42 volts.
Josh
Old 11-09-2012, 07:10 AM
MC5C MC5C is offline
MC5C has a very good reputation on FTE.MC5C has a very good reputation on FTE.MC5C has a very good reputation on FTE.
As a FWIW reference point, my truck seems (knock on wood) to have a healthy FICM. Monitor voltages with Scangauge, cold start at freezing shows 48 - 49 volts from start-up through the glow plug phase and normal running is 48.5 - 49 volts.
Brian
Old 11-09-2012, 08:09 AM
Will Bite's Avatar
I've seen my cousins 07 read 51v at start and running, and its all stock. My truck seams to run great but was under the impression once the volts start to drop below 48v it was on its way out.
Old 11-09-2012, 08:15 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Anything below 45, not 48, is a failing or failed FICM and needs to be repaired. Sometimes a failed FICM doesn't drop below 48V and still has failed.
Old 11-09-2012, 08:36 AM
Thanks bullitt390, I will check this out pretty close. I think I even saw 39 just after start up, I tought it could drop below 45 until glow plugs where done??
I will check my battery voltage too. I am checking this out because I noticed a few misses and rough running for a short period after start up when the wheather was around 23 F.
I have read the teck folder and it shows how to check the FICM at the 4 screws. As I understand you can fix a low voltage by resoldering?
Old 11-09-2012, 08:40 AM
Bullitt390's Avatar
Anything below 45 volts at ANY time is considered a failed FICM.
I would send my failed FICM to ficmrepair.com and have Ed work his magic. I have fairly good knowledge of electrical work and soldering, plus i am a cheap ******* and even I wouldn't attempt to repair my own FICM
Josh
Old 11-09-2012, 10:31 AM
Will Bite's Avatar
So I'm ok because mine stays between 46.5v and 48v. I've never seen below 46.5v at any time. I was just trying to catch it early to have Ed on it before it went completely south.
Old 11-09-2012, 10:37 AM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
Yes, your ficm is fine.
2003 Bad HPOP?? spanky350 6.0L Power Stroke Diesel 68 01-30-2017 04:51 PM
New FICM issues. Thor'sHammer 6.0L Power Stroke Diesel 78 06-19-2016 11:12 PM
FICM voltage samsdad02 6.0L Power Stroke Diesel 31 08-18-2014 06:44 PM
Help with readings spanky350 6.0L Power Stroke Diesel 12 04-27-2014 05:25 PM
First Use of AutoEnginuity: FICM on the way out, some HP oil questions... Agentx86 6.0L Power Stroke Diesel 21 10-15-2009 10:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
