2004 Expy plug change - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 11-08-2012, 12:28 PM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
I changed my plugs today with Motorcraft plugs. 4.6L one piece plug is a much easier chore than the older 5.4's.
I really could have waited as I have 92K on the clock and the plugs looked amazingly awesome. No misfiring or any symptoms, i just figured that I would be proactive.
Next time I'll examine the first one that I remove and make a decision whether or not to continue.
Old 11-08-2012, 03:23 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
There is no guarantee that the next 7 will look the same as the first one. You will have to remove and inspect all of them if you want to be sure.
A couple of months back I had a misfire in my Mustang. I figured I'd start with the plugs since they were about 4 years old. Every plug looked perfect until I got to the 8th one. It had carbon build-up on it to the point of having bridged the gap between the electrodes. With the 8 new plugs installed the misfire was gone. Now if I had stopped after the first one because it looked good, I would've wasted a lot of time trying to track down the problem elsewhere. The moral is assume nothing and double check everything.
Old 11-10-2012, 06:59 PM
Deadstick 8409 Deadstick 8409 is offline
Deadstick 8409 is starting off with a positive reputation.
The 2004 expys did not have the two piece plug, that came with the 3valves for 2005.
Old 11-10-2012, 09:53 PM
tseekins's Avatar
Quote:
Yeah, I know. It was more of a celebratory statement.
Spark plug change walk though 69Boss521 1999 to 2016 Super Duty 10 07-01-2009 05:27 PM
Spark plug change bigstoner 2004 - 2008 F150 29 11-30-2008 10:34 PM
Number one plug- what a joy! Steve 1987 - 1996 F150 & Larger F-Series Trucks 0 03-28-2007 09:55 PM
Wiring 220V plug; Four pin to Three pin FarmLaw Garage & Workshop 7 05-08-2006 02:18 PM
Coolant in a plug hole TheBigF 1997 - 2003 F150 1 06-02-2005 08:43 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
