Largest rims to put on Mustang II IFS '54 f100? - Ford Truck Enthusiasts Forums
Old 11-08-2012, 12:11 PM
slaney30 slaney30 is offline
slaney30 is starting off with a positive reputation.
So here's my plan... I'm getting a Jim Weimer Mustang II IFS kit with either 2" drop spindles or regular spindles.
Im going to use air ride suspension. Does anybody have any idea of the largest size rim I can put on the front IFS? Can I put 18's in there?
Also will it matter if I get regular or drop spindles? I want a lower ride height, and i'm not sure if the bigger rims will determine which spindles I should get.
Lastly, what size of rear rim should I run? Will 20" fit?
Thanks for all the help in advance, this forum is awesome!
Old 11-09-2012, 09:59 AM
CdnWillyG's Avatar
CdnWillyG CdnWillyG is offline
CdnWillyG is starting off with a positive reputation.
Just a heads up on the drop spindles, I'm only running 15" rims and my clearance is only 8" to the bottom of the front bumper using regular spindles. Now larger tires will give a great clearance but at 8" I worry about coming off rounded curbs and speed bumps hitting....my 2 cents.
Good luck!
Old 11-09-2012, 10:22 AM
rjinator3.0 rjinator3.0 is offline
rjinator3.0 is starting off with a positive reputation.
20s on M2 suspension with drop spindles.
<a href="http://s103.beta.photobucket.com/user/rjinator/library/F100%20BUILD" target="_blank"><img src="http://i103.photobucket.com/albums/m156/rjinator/F100%20BUILD/IMG_0555.jpg" border="0" alt="Photobucket"/></a>
Old 11-09-2012, 09:19 PM
ben73058's Avatar
ben73058 ben73058 is online now
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
Hey Slaney,
Hmmmm... Tricky question on what size wheel you can run.
Our truck is a 1950 F1 with a Mustang II front end with coilovers -
standard axle - not dropped. The Mustang II drops the front end quite a bit - not sure a drop spindle is required.
We've really struggled with the wheel/tire size issue - we initially went with 18's front & back with 255-45-18 tires - 27 inch diameter/10 inch width. That's a pretty low profile tire & it didn't work up front - hit on dips & rubbed (a lot). We put in spring spacers & jacked the coilovers up to the max & it still didn't really work i.e. couldn't be aligned.
I went even smaller on the tire this week & it fits - 225-40-18's - that's a very low profile tire.
There's a lot that needs to be thought through - measure, measure, measure & talk to to some real wheel/tire guys. A lot depends on the Offset so you can tuck them in under the front fenders.
Good luck over there. Our truck's stance with 18's up front (see pic).
Ben in Austin
1950 F1 (351W/AOD)
Trade drop spindles for stock jrockdiddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 10-29-2016 01:06 AM
need to buy rims and tires for IFS - Need advice slaney30 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 05-02-2013 02:49 PM
MustangII IFS questions for 52 F-1 wld427 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 03-23-2013 11:56 PM
MII front suspension kit - which kit to buy slaney30 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-26-2013 02:27 AM
51 F1 Mustang-II IFS selection time Jaybird51 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 09-07-2012 07:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
