Engine making noise? - Ford Truck Enthusiasts Forums
Old 11-08-2012, 11:45 AM
SuperDuty93's Avatar
SuperDuty93 SuperDuty93 is offline
SuperDuty93 has a good reputation on FTE.SuperDuty93 has a good reputation on FTE.
So recently I've noticed that in the morning when I go to start my 390 (cold start), it fires right up BUT it makes a almost nocking type noise.... It goes duh duh duh ...... Duh duh duh ....... It has a few second pause in between but it also seems to stop once warmed up. Its almost a deep exhaust decible noise doesnt really sound like nocking on metal. I really hope it isn't a bad knock :/ anyone have any ideas?
Old 11-08-2012, 03:32 PM
SOB Racing's Avatar
SOB Racing SOB Racing is offline
SOB Racing is starting off with a positive reputation.
Try adding some thick oil like lucas oil additive it will help keep upper parts lubricated when motor sits. good place to start.
Old 11-08-2012, 05:22 PM
Already ahead of ya. I have the Lucas stabalizer in there with my last oil change. Few weeks or maybe a month ago. Um I'm going to check my oil level to see if I needto add any. Should I put in a bottle of break in cam oil stuff from Lucas every oil change cuz I heard it has zinc in it or something like that Whig is good for flat tappet cams and I have a newer cam in it and don't wana ruin it ( I broke it in like 8 months ago).?
Old 11-08-2012, 11:16 PM
ok well it was low on oil but even after i put a quart or 2 in and drove it, its still there. I got under the truck and i cant tell if its from the engine or mufflers. To me i think its coming from the mufflers or the X pipe but its to damn loud to hear haha
Old 11-09-2012, 11:06 AM
SOB Racing's Avatar
If it goes away after warm up you might want to pull valve covers and check rocker arm to push rod clearance.
Old 11-09-2012, 12:17 PM
I just you tubed engine knocks to see what it would sound like and what I'm talking about sounds nothing like what was on you tube. Anyone have a video in particular that should sound like a knock in a 390?
Old 11-09-2012, 12:29 PM
Jimmyrig Jimmyrig is offline
Jimmyrig is starting off with a positive reputation.
Do you have catalytic converters on it? If so it could be a busted cat. Otherwise I'd go with valves. I had a strange knocking in my cherokee once. A month later I ended up with my rods and crank all over the road...
Old 11-09-2012, 12:34 PM
Quote:
But the thing is I'm not so sure it's a knock. Cuz it seems to be coming from the flow through the exhaust and the engine doesn't seem to be making the noise. And I don't have cats either. Umm ima try to identify the source again when I get home.
Old 11-09-2012, 12:40 PM
pick up a cheap stethoscope on your way home. Start at the valve covers and work down then back. Might be loud as hell but its like finding a stud in a wall.
Old 11-09-2012, 12:48 PM
Dads a doctor so I already have a few and I think I can rule out a tick or engine knock cuz every you tube video I've watched is. Completely different then what I'm hearing. I think it has to do with my X pipe sobim 95% sure it's an exhaust sound from my new system..... I'll get the scope out and listen just in case though .
Old 11-09-2012, 12:58 PM
smokenchoken's Avatar
smokenchoken smokenchoken is offline
smokenchoken has a good reputation on FTE.smokenchoken has a good reputation on FTE.
9 times out of 10 its a blown exhaust gasket or even an exhaust donut i betcha thats what it is since its very common with all fe's
sunroof and foglights problem ncbeachbum 1999 to 2016 Super Duty 0 03-24-2015 03:22 PM
Gotta wonder about some people these days Redrkt 1999 to 2016 Super Duty 12 08-06-2014 04:38 PM
Dash acting up Aetic 1994.5 - 1997 7.3L Power Stroke Diesel 0 05-29-2014 10:23 PM
Running in 2wd with hubs locked, ok ... ? Hussler 1994.5 - 1997 7.3L Power Stroke Diesel 20 12-12-2013 02:33 PM
Light Bars? SuperDuty93 1973 - 1979 F-100 & Larger F-Series Trucks 1 07-16-2011 11:58 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
