Auto Unlock Question
This is probably a dumb question, but I can't seem to find the answer in the owners guide or by searching the forum.
When I turn off my Ex, the drivers door unlocks automatically, but the other doors remain locked. Is there a way to program it so that all doors unlock automatically? (I know I did that on my wife's Mazda)
Have you tried the following? (Article on FTE by Rollie Trimmell)
If you have a late model Ford truck you can enable or disable the auto-lock feature by follow the directions below. Generally the auto-lock feature is turned on by the factory when the truck has an automatic transmission and it is turned off from the factory on trucks with a manual transmission.
The system will in most cases revert back to the original setting anytime you disconnect the battery. I understand that these directions will work on any late model Ford vehicle but I have only performed it on the Ford trucks.
