View Poll Results: starter motor for engine B9AE6015F
B9AE6015F
0%
B9AE6015F
100.00%
Voters: 1. You may not vote on this poll
Old 10-01-2012, 03:07 AM
ger_man's Avatar
ger_man
ger_man is offline
hi there
maybe anybody can help me ? i`m from germany and own a F100 (1960) third generation with V8 engine.
donīt know if the engine is the original in it but can send pictures for more clearness. number on the block is B9AE 6015 F
i urgently need a starter motor for my truck.
if anybody could help me that would be very great.
thxs raik
Old 10-01-2012, 05:56 PM
spurredon's Avatar
spurredon
spurredon is offline
Welcome! Yes, pictures are always helpful. Do you have a starter that is not working or none at all?
Old 10-01-2012, 06:07 PM
spurredon's Avatar
spurredon
If you have a 1959 engine as your casting number indicates, this one on Ebay should work for you, then again I don't know exactly what engine you have for certain. Check it out! 56-62 FORD/MERC. REBUILT STARTER W/WARRANTY (NICE) #1 | eBay
This fella has been selling these rebuilts for quite awhile now.They are getting harder to find.
Old 10-02-2012, 01:58 AM
ger_man's Avatar
ger_man
ger_man is offline
hi again
much thanks for your kindly help in this case. the starter motor on ebay is nearly the same like mine but the shaft from my starter is a little bit longer and there is not a spring coil in front of the shaft. the body and the holder, respectively the flange is the same. i would attache a picture but don`t know how it works.
thxs raik
Old 10-02-2012, 06:25 PM
spurredon's Avatar
spurredon
Here's a link describing how to post pictures! https://www.ford-trucks.com/forums/6...-pictures.html
Old 10-02-2012, 06:47 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
http://i285.photobucket.com/albums/l...ghtsafter1.jpg
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
Old 11-09-2012, 10:06 PM
bblauvelt's Avatar
bblauvelt
bblauvelt is offline
I bought mine here
I used it for a 292 and use the old one, before I broke rebuilding, it on the 223:
DB Electrical - NEW STARTER FORD, MERCURY FROM DB ELECTRICAL 3115
Old 11-09-2012, 10:10 PM
bblauvelt's Avatar
bblauvelt
BTW - Your casting is a 292 Y block
Casting info can be found here:
TECHNICAL
Old 11-10-2012, 07:27 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Do you need the complete starter or just the Bendix drive?
The starter drive is the Bendix inertia type, has a huge coil spring on it.
It's retained to the shaft with a roll pin. The drive has to unwound by hand to get to the pin.
C1AZ-11350-A (replaced 1CM-11350-C) .. Bendix Drive / Obsolete ~ 54 available NOS
1952/60 F100/800 215/223 I-6 & 239/256/272/292 V8 / Misc: 1952/60 Ford I-6 & V8 Passenger Cars.
Tim J
09-13-2014 03:58 PM
Borax
10-07-2013 11:04 AM
ger_man
09-30-2012 01:22 PM
allanoldtruck
07-12-2006 11:22 PM
Purely Ford
05-23-2005 12:33 PM
Quick Reply: starter motor for engine B9AE6015F
