fuel pump - Ford Truck Enthusiasts Forums
fuel pump
Old 11-07-2012, 11:33 PM
Fett Affen's Avatar
Fett Affen Fett Affen is offline
Fett Affen is starting off with a positive reputation.
fuel pump
I am on my third air dog ll and this one started sounding like a garbage disposal after about 3000 miles, the second one lost pressure after about 2000 miles. What pumps are you guys using with B100? The factory pump quit at 90,000. I like the ease of filter change out with the air dog.
Old 11-08-2012, 07:40 AM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
Rushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud of
I am on my second fuel pump, it's a heavy-duty from NAPA.that was about 12000 miles ago at 160,000.
Old 11-08-2012, 09:22 AM
Fett Affen's Avatar
Problem is, mine is a 6.0 and requires a minimum of 45 psi. What does the 7.3 require? Federal Mogul (Carter) makes a brushless inline that is rated for B100 but I can't find specs on it.
Old 11-08-2012, 06:15 PM
Rushmore X's Avatar
no idea, sorry.
Old 11-08-2012, 09:08 PM
1989f250IDI's Avatar
1989f250IDI 1989f250IDI is offline
1989f250IDI is starting off with a positive reputation.
B100 is probably to thick on that pump and it just eats it up. Try a mixture of like 80/20 on a new pump and watch it last a very long time. Also what filter do you use
Old 11-08-2012, 11:28 PM
Fett Affen's Avatar
The first air dog lasted 75000 miles, the reason it quit was that when I took it to a motor rebuilder, he discovered that the springs that put pressure on the brushes were installed backwards and that only allowed only about 20% pressure on the commutator which in turn generated heat which is not good on any motor. I had him rebuild it and that is my emergency spare. The filter I run on it is a Wix 6 micron at the pump and the factory 2 micron in the engine compartment. If anyone has any idea where to buy just that small 2 micron filter, I would like to know. My final filtering of my bio is 1 micron nominal. The absolute filters are very expensive but I have gone as much as 20,000 miles on one filter.
Old 11-09-2012, 03:37 AM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant future
I gave up on the FASS pumps. They are noisy, have a limited lifespan and cost too much to rebuild.
The stock PSD pump is rated for 110psi and is more than adequate to pump any fuel that has a low enough viscosity to work good in your truck. The 7.3 fuel pressure regulator is in the fuel bowl, so as long as you supply enough volume to it - it's fine. Not sure about 6.0 regulator. NONE of these high volume/high pressure pumps like restriction pre-pump. Many people make the mistake of putting a 'primary-type' filter in front of the pump - this results in poor performance and short pump life... That said, the 'Hutch' in-tank mods are eventually required on all of these trucks (7.3's anyway) to eliminate the strainer/filter in the tank. Just use something like WIX 33972 in front of pump (all this filter does is protect the pump).
Here's a Made in USA 7.3 pump for $40 shipped - with a lifetime warranty:
New Fuel Pump Installation Kit Ford Pickup Van 7 3L Diesel E2236 | eBay
Not sure how they hold up yet, but know a few people using them in SVO conversions right now...
Old 11-09-2012, 09:23 AM
kirkharrod's Avatar
kirkharrod kirkharrod is offline
kirkharrod has a good reputation on FTE.kirkharrod has a good reputation on FTE.
I have 4,000 miles on one of those $40 pumps. So far, so good.
Old 11-09-2012, 10:10 AM
Quote:
Good to know! Thanks Kirk!!
Air Dog II + Filter System Spool&Go 1999 - 2003 7.3L Power Stroke Diesel 5 12-08-2014 09:17 PM
Engine runs rough after fuel system modification bigbubba87 1999 - 2003 7.3L Power Stroke Diesel 10 12-02-2014 02:37 PM
Aftermarket Fuel System Mortoys 1999 to 2016 Super Duty 0 10-17-2011 03:57 PM
Squealing fuel pump, how long before it dies? mtboys84 1999 - 2003 7.3L Power Stroke Diesel 9 12-24-2010 08:50 PM
Carter P74221 Fuel Pump ??? Craig64 1999 - 2003 7.3L Power Stroke Diesel 0 02-11-2007 08:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
