accelerator linkage piece needed for '56 223 - Ford Truck Enthusiasts Forums
Old 11-07-2012, 10:36 PM
dbaldw dbaldw is offline
dbaldw is starting off with a positive reputation.
I am looking for a piece of the accelerator linkage for a 1956 223. I have the longer rod which goes from the pedal linkage on the firewall. I have the little flipping piece that sits on a bolt on the intake manifold. But I need the short rod that then must connect to the ball on the carb which is a Holley 1904. any ideas where i could find the little rod? thx, david baldwin
Old 11-08-2012, 09:38 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Hmmm.. I may have one.
Old 11-09-2012, 01:06 AM
great thanks
i'll take a picture of the sequence of parts that I have and send it along.
Old 11-09-2012, 05:30 AM
55 f350's Avatar
55 f350 55 f350 is offline
55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold
if panelman doesn't have one heres two possibilities . one any 54 through 56 v8 and six used the same linkage on the left side of the intake versus the right side contraption i have on my flathead .......... dennis carpenter sells the whole shabang for like 48 bucks in his catalog . if neither of these work dig into reds online catalog or speedways street rod catalog or their dirt track catalog as you will find all sorts of things you can use to accomplish what you want , unless your trying to go for one of those puckered **** restorations where its gotta be 100 percent the way it was or it will never do ................
Old 11-09-2012, 06:23 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Welcome to FTE
THREE different short rods: Ford-O-Matic rod different than 3 speed with/without O/D rod, different than 3 speed rod w/a governor.
AD-9772-A .. 2.03" between ball joints centers / Obsolete
1953/56 F100/350 OHV I-6's with Ford-O-Matic.
EAG-9772-A .. 4" long-use with 3 M/T with governor / Obsolete
1953/56 F100/600 OHV I-6's.
TRAA-9772-A .. 2.10" long from center of rod end to ball socket / Obsolete
1953/56 F100/600 OHV I-6's with 3 M/T with/without O/D / 1952/53 Ford Passenger Cars 215 I-6 3 M/T with/without O/D.
> 1948/56 Ford Truck Parts Catalog available on a CD from hipoparts.com <
Old 11-09-2012, 09:44 AM
55 f350's Avatar
all hail the great number dummy !!!!!!!!!!! bill always has the answers . he is an invaluable resource of information . forgive the image bill but we need one to bow to to your greatness .............Name:  kazoo.jpeg
Old 01-05-2013, 11:06 PM
Quote:
Originally Posted by tyrantsparky View Post
I have a '62 f100 and just purchased a Holley 1904 and am having a hard time connecting it because I think I have the same set up and am missing the same part. If any one has pictures of how this is supposed to look when it's done, and could suggest where I might find this part in Phoenix, it would be much appreciated.
Welcome to FTE
I asked a moderator to move your thread to the 1961/66 forum as you'll get more help there. This is the 1948/56 forum.
Tis a common mistake typing initial threads in wrong forums.
Old 01-05-2013, 11:09 PM
tyrantsparky's Avatar
tyrantsparky tyrantsparky is offline
tyrantsparky is gaining momentum as a positive member of FTE.
Unhappy
Thanks for the redirect...
Old 01-05-2013, 11:11 PM
I have a 1962 F100 and just purchased a Holley 1904 and am having a hard time connecting it because I think I have the same set up and am missing the same part. If any one has pictures of how this is supposed to look when it's done, and could suggest where I might find this part in Phoenix, it would be much appreciated.
Welcome to FTE
FTE has an AZ Chapter, the chapter leader is FTE member Bill W (Tucson). Chapter has members that have like trucks as yours, post daily in 1961/66 forum.
Old 01-05-2013, 11:14 PM
Fomoko1's Avatar
Fomoko1 Fomoko1 is offline
Fomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputation
Thanks for the heads up Bill.
Old 01-06-2013, 10:11 AM
DR Smith's Avatar
DR Smith DR Smith is offline
DR Smith has a great reputation on FTE.DR Smith has a great reputation on FTE.DR Smith has a great reputation on FTE.DR Smith has a great reputation on FTE.
I have the complet linkage for a 54 239ohv v8 and auto trans if you need it .
Old 01-06-2013, 01:06 PM
thanks, i already found one.
F-6 Gas peddle drags against cab chrislynn5 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 06-19-2016 08:48 PM
1984 150 accelerator pump rod SS502MC 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 02-13-2016 06:29 PM
Need help with shifter linkages dnsenne 1961 - 1966 F-100 & Larger F-Series Trucks 20 05-26-2015 08:15 PM
Source for carburetor linkage brit_wheels_fan 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 04-06-2015 05:05 PM
Clutch t98 292 schoo 1961 - 1966 F-100 & Larger F-Series Trucks 4 12-28-2012 04:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
