ignition box replacement? - Ford Truck Enthusiasts Forums
Old 11-07-2012, 08:19 PM
dyoungen dyoungen is offline
dyoungen is starting off with a positive reputation.
We're replacing a 1976 360 with a 300 six. The 360 has the silver box, ignition box I would guess and I"m wondering if I can use the box or something else on the 300. Both haver electronic ignitions. Is there any market for a 360 block or heads?
Old 11-07-2012, 08:44 PM
79_FORD_F-100's Avatar
79_FORD_F-100 79_FORD_F-100 is offline
79_FORD_F-100 is starting off with a positive reputation.
Msd, mallory, maybe accel.
Old 11-07-2012, 08:45 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Look on the ignition module above where the wires feed out for a colored plastic square used for identification. 1976: It should be blue.
Module mounted to the left (drivers) side inner fender apron. Genuine Ford marked MOTORCRAFT and has Ford ID numbers molded on it (one 1976/78 example: D6AE-12A199-A1A).
DuraSpark Electronic Ignition introduced in 1974, but not all vehicles came with it until 1976.
Blue module same regardless of engine size, makes no difference if a Passenger Car/F100/350/Bronco/Econoline.
1U2Z-12A199-AA (replaced D6AZ-12A199-A & D9VZ-12A199-A) .. DuraSpark Ignition Module - Blue (Motorcraft DY-893) / Available from Ford.
Applications: Myriad 1976/97 FoMoCo vehicles.
Old 11-07-2012, 09:27 PM
How would I go about hooking up the ignition box to the distributor on the 300?
Old 11-07-2012, 09:58 PM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
If the 300 has the same connector coming from the distributor as the 360 did (3 terminals with ORANGE, PURPLE and BLACK wires), then you hook up the 300 in the exact same way as the 360.
Old 11-08-2012, 10:02 AM
The distributor on the 300 only has 2 wires. The distributor connections that were on the 360 are still in the truck so I'm thinking of splicing into them but would rather be sure before I fry something.
Old 11-08-2012, 11:44 AM
shortboxjay's Avatar
shortboxjay shortboxjay is offline
shortboxjay is starting off with a positive reputation.
Have you already hooked up the coil....cause it only has two wires going to it. I think you should have three going to dist, unless your running into a duraspark 1 vs duraspark 2 issue. They are not the same. a 360 is a older model76 and under I beleive, and might have had a duraspark 1 system on it....77,78,79 all had duraspark 2 system. the ignition boxes are diffrent also, dura 1 has two plugs, one with 4 wires and the other2 wires, duras 2 has one with 4 wires and one with threee wires, that go to dist. From what I can remember.
Old 11-08-2012, 12:06 PM
Quote:
They are not the same. a 360 is a older model 76 and under I believe and might have had a duraspark 1 system on it....77,78,79 all had duraspark 2 system. the ignition boxes are diffrent also, dura 1 has two plugs, one with 4 wires and the other2 wires, duras 2 has one with 4 wires and one with threee wires, that go to dist. From what I can remember.
1974/79: There are FIVE different ignition modules.
1974 module is 1974 only / 1975 module is 1975 only / 1976, there are THREE different modules, one was only used in some CA vehicles.
Modules have a colored plastic square above where the wires feed out, used to ID them. The OP needs to verify which module his truck has.
ALL 1976/79's use the SAME module if it has a BLUE square. Blue Motorcraft modules marked with ID numbers:
D6AE-12A199-A1A or A2A or A1B or A2B / D8VE-12A199-A1B or A2B or A1C or A2C
1977: The V8 dizzy cap changed, has 9 male ends and an adapter below that the cap clips onto.
Old 11-08-2012, 01:19 PM
fmc400's Avatar
MSEE
A factory Ford distributor with electronic ignition should have 3 wires coming out. Please post a picture. Sounds like you have something aftermarket (maybe a Pertronix kit in a points distributor). Do not splice anything because we don't know what you're looking at. You will only create issues that we will have to help you undo later.
Old 11-08-2012, 01:22 PM
the three modules in 76 i beleive were duraspark1 and duraspark 2 and duraspark2 with elevation spark retard (yellow block on module), that 76 he has his 360 in is probably a duraspark 1 which has a diffrent plug on the module, and not compatable with a durasprk1 distributo. The plugs don't match up. Maybe a 240 six cylinder dist would work . Did they offer a 300 six in 76??? or was it still a 240???
Old 11-08-2012, 01:40 PM
fmc400's Avatar
MSEE
He needs to respond to my question first. I want to keep things simple.
To answer your questions though, Duraspark 1 should be gone by 76 (someone can correct me if I'm wrong). All Durasparks have a hot-in-START spark retard function; the degree of retard varies with grommet color. Elevation does not tie in to the common blue-grommet Duraspark 2 module.
Back to the main topic, OP please post a pic of what is coming out of your distributor, a shot with the cap off would be nice too.
crazy96863's Avatar
crazy96863 crazy96863 is offline
crazy96863 is gaining momentum as a positive member of FTE.
Slightly off topic but... Is your truck the 360 coming out of a 4x4? If so, i will throw you a bone for the powersteering pump bracket.
Old 11-08-2012, 01:42 PM
crazy96863's Avatar
Heck maybe even if its a 2x4... I think the pump i the same. Let me know if your willing to part with it.
Old 11-08-2012, 01:48 PM
I hear ya fmc400...need some pics to see whats going on. Didn't mean to be confusing, went through this stuff 15 years ago, and though he might be haveing the same issue I had.
Old 11-08-2012, 07:34 PM
Sorry guys but I can't get the pictures till tomorrow am. As for the power steering bracket, we plan to keep the power steering.
wiring tsoza86 1967 - 1972 F-100 & Larger F-Series Trucks 2 07-18-2015 12:50 AM
New ignition coil needed jomoflymo 1973 - 1979 F-100 & Larger F-Series Trucks 3 08-10-2014 08:11 AM
Ignition probs and XPI Xtra Power Ignition Cdouglas18 1973 - 1979 F-100 & Larger F-Series Trucks 4 01-23-2014 09:43 PM
points to electronic ignition on 360/390 rebocardo 1967 - 1972 F-100 & Larger F-Series Trucks 3 07-05-2002 07:46 AM
360 and 390 ignition timing jowilker FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 04-25-2002 02:29 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
