HID high beam ?? - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
HID high beam ??
Old 11-07-2012, 02:02 PM
05Eddie 05Eddie is offline
05Eddie is starting off with a positive reputation.
HID high beam ??
I have the Retro-Solution Digital kit on my 2005. While the low beams look great, the high beams are not much brighter...Is this a standard problem with the after market HID's? I need a much brighter high beam !
Old 11-07-2012, 05:14 PM
Joe28443's Avatar
Joe28443 Joe28443 is offline
Joe28443
Joe28443 has a very good reputation on FTE.Joe28443 has a very good reputation on FTE.Joe28443 has a very good reputation on FTE.Joe28443 has a very good reputation on FTE.
Mine is the same way
Old 11-07-2012, 09:35 PM
william_04_x's Avatar
william_04_x william_04_x is online now
william_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputation
Are you running 55wt or 35wt? Either way, the problem is more the headlamp housing, than the HID kit. The RS hi/lo kits use a solenoid to move the lamp just a bit to alter the beam pattern. The amount of light output from the lamps is the same in hi or low. The lamp doesn't turn off when switching hi/lo, it just moves, so warm up time isn't an issue.
The only real solutions, try re-aiming what you have, installing projector housings into the factory headlights, buying aftermarket replacement projector headlight housings, or adding additional axillary lighting.
Old 11-07-2012, 10:25 PM
AlaskanEx's Avatar
AlaskanEx AlaskanEx is offline
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
mine are pretty good, but i have the 02-04 heads. but i added 4 100W lights to the front for alittle extra
Old 11-08-2012, 08:27 AM
I played with the aim last night.. Made it alot better..The highs are still pretty much useless...but i love the look.
Could not resist some new lights for my 6.7 LA2005F250 6.7L Power Stroke Diesel 4 03-28-2013 01:05 PM
Installed new HID Headlights..Now Fog lights do not work??? Finally Powerstrokin 1999 - 2003 7.3L Power Stroke Diesel 2 10-09-2012 07:51 PM
HID lights tbaker00 6.7L Power Stroke Diesel 114 03-18-2012 05:52 PM
DRL's and Heavy duty headlight harness BCHauler 1987 - 1996 F150 & Larger F-Series Trucks 20 10-19-2011 02:38 PM
HID Conversion installed on my F-350 Milwaukee,WI 1999 to 2016 Super Duty 56 08-25-2009 07:51 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
