390 pistons?
Old 11-07-2012, 09:00 AM
cws10190's Avatar
cws10190
cws10190 is offline
390 pistons?
i have a number on the pistons of my 390 they r l2245 pistons i have looked for them but cant find anything for 390 l2245 pistons
Old 11-07-2012, 02:13 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,591 Likes on 1,296 Posts
Those are pistons out of your motor? Are they going back in?
Any other markings? Flat, dome or dish? Compression height?
Old 11-07-2012, 04:01 PM
cws10190's Avatar
cws10190
cws10190 is offline
yes those are in my motor no other marking beside std. i plan on leaving them in. unless i decide otherwise. believe they r 2 relief dish pistons. dont know compression tho
Old 11-07-2012, 09:43 PM
vwfreak's Avatar
vwfreak
vwfreak is offline
Pictures??
I just picked up a 390 and am looking forward to getting inside and seeing how different it is from my '67....
Old 11-07-2012, 11:11 PM
85e150's Avatar
85e150
85e150 is offline
L2245 comes up as a 428 piston. Check that bore!!!
332-428 Ford FE Engine Forum: TRW L 2245 Forged Pistons
https://www.ford-trucks.com/forums/1...e-pistons.html
https://www.ford-trucks.com/forums/2...endations.html
4.13 vs 4.05 bore. A little over 4 or a little over 4 1/8th via the tape measure method....
Old 11-09-2012, 05:49 PM
cws10190's Avatar
cws10190
cws10190 is offline
came out to be 4.111 bore give or take 2
Old 11-09-2012, 07:17 PM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
sounds like you won the 428 lotto .. SCORE!!!!
Old 12-09-2012, 05:13 PM
nobearsyet's Avatar
nobearsyet
nobearsyet is offline
Dude you're lucky.
Old 09-09-2014, 10:22 AM
jrods2's Avatar
jrods2
jrods2 is offline
piston bore
you have a 390 bored .060 over, 428 std bore is 4.135. I've seen so much false info about the 390 that it's mind boggling. The only way to tell what you have is to dismantle it and check numbers. most of the tags that were attached to the original carb stud have been lost & thrown away. no exceptions.
cws10190
11-07-2012 09:36 AM
79f100six
02-27-2010 01:53 AM
MaximumMax001
07-18-2004 03:32 PM
Brad Deicke
08-21-2002 05:08 PM
Quick Reply: 390 pistons?
