Cummins in Ford - Ford Truck Enthusiasts Forums
Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
Cummins in Ford
Old 05-21-2003, 12:44 PM
jjsj38 jjsj38 is offline
jjsj38 is starting off with a positive reputation.
Cummins in Ford
I own a 99 ram with the cummins, tranny rebuilt once at 65k, truck now has 89k. When I was at Cummins Power Systems buying a fuel filter, the man at the counter said that Ford was putting the cummins in their 2005 model pickups. Has anybody heard this???? Looking into purchasing another Ford one day but would like to have the cummins motor
Old 05-21-2003, 02:19 PM
johnsdiesel's Avatar
johnsdiesel johnsdiesel is offline
johnsdiesel is starting off with a positive reputation.
Cummins in Ford
This isn't true. You can get a conversion kit to install a Cummins in a Ford pickup, but Ford isn't offering it as a factory option. If you want the 5.9 Cummins in a Ford you'll have to buy an F650 or F750, and at that point I'd get the Cat diesel.
Old 05-21-2003, 02:34 PM
Cummins in Ford
So your saying if i order a new 350, i can request a cummins or order it without a motor and have it installed
Old 05-21-2003, 03:09 PM
Cummins in Ford
Quote:
No. I'm saying that there are aftermarket conversion kits available to put a Cummins in a Ford. I don't think Ford sells trucks without engines.
Old 05-21-2003, 03:49 PM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
Cummins in Ford
you can get the cummins in ALL the fleet model trucks. From the 350 on up.
Old 05-21-2003, 04:59 PM
Cummins in Ford
i want the f 350, so it doesn't come in the f series
Old 05-21-2003, 06:56 PM
BobbyL BobbyL is offline
BobbyL is starting off with a positive reputation.
Cummins in Ford
I just went to Ford's commercial website and there are no 5.9 Cummins options for anything smaller than F-650.
Old 05-21-2003, 06:58 PM
pfogle's Avatar
Cummins in Ford
I thought they were offering them in the "fleet" line, but that's been a couple months since I checked the website tho.....
Old 05-22-2003, 05:52 AM
Aten Aten is offline
Aten is starting off with a positive reputation.
Cummins in Ford
Quote:
At this point I think the 5.9 theyre using is a medium duty, not the kind theyre sticking in the Dodge trucks right now, not exactly the kind of motor you would really want for a regular pu I think. Besides, its like this guy says, the cat diesel is the way to go, the only problem is it kind of sucks to buy all the stuff to make the vehicle a 4x4 afterwards.
Old 05-22-2003, 09:09 AM
dman01 dman01 is offline
dman01 is new and has a neutral reputation at this point.
Cummins in Ford
yes there is only 1 5.9 Cummins diesel. The one they put in the Ford trucks are the same one the put in the dodge trucks. You can get a quiet 305hp F-650 now I thought that was kinda funny sense Ford and Dodge keep figthing for the higher HP diesel and if you buy Ford you can get both. It would make a great comparison. same truck same load different engine.
Old 05-22-2003, 09:31 AM
da cubs da cubs is offline
da cubs is starting off with a positive reputation.
Cummins in Ford
Check out the Ford F100 from the Ford-argentina web site. They sell in Argentina, an F100 pickup that looks exactly like an F250, and they DO, in fact, put a 5.9L Cummings in the truck!
Old 05-22-2003, 10:36 AM
Cummins in Ford
The Cummins they're using in the F650 and F750 is the same engine that is used in the Dodge pickups, but it is tuned differently. There are 5 different "tunings" of this engine available:
185 HP @2400 RPM 420 lb/ft @1600 RPM
215 HP @2300 RPM 520 lb/ft @1600 RPM
230 HP @2300 RPM 520 lb/ft @1600 RPM
245 HP @2300 RPM 660 lb/ft @1600 RPM
260 HP @2300 RPM 660 lb/ft @2500 RPM
Old 09-30-2009, 12:18 PM
ericksmi ericksmi is offline
ericksmi is starting off with a positive reputation.
cummins in 93 F250
Is there any easy way to put a Cummins diesel in a 93 F250 to replace the current Navistar engine?
Old 09-30-2009, 01:20 PM
BigDaddy6969 BigDaddy6969 is offline
BigDaddy6969 is starting off with a positive reputation.
Way to bump a 6 yr old thread.
Old 09-30-2009, 05:59 PM
scraprat's Avatar
scraprat scraprat is online now
scraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud of
Quote:
He used the search and responded to a thread even if it's slightly long in the tooth. I'm giving rep points to him. How times have we seen the same old ?'s asked over and over again.
Uh-Oh! I Just Bought A Cummins... 1972RedNeck Engine Swaps 59 11-18-2016 11:42 AM
Not A Ford Truck But Cool 1949f1 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 09-10-2016 01:07 PM
Ford & Cummins hammer65 1999 - 2003 7.3L Power Stroke Diesel 17 06-08-2012 08:31 PM
cummins conversion Dillin 1961 - 1966 F-100 & Larger F-Series Trucks 18 03-20-2009 03:47 PM
Cummins/Ford bczolone General Diesel Discussion 48 12-09-2005 10:40 PM
Tags
2003, 59, cummings, cummins, diesal, f350, f750, factory, ford, inford, installing, option, pickup, start, switch, w
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
