my truck fixed its own light bulb
Shortly after buying my truck, the bulb behind the PRND321 on the dash went out by the P and R. Its been dark by those 2 letters for almost a year and a half now. Today, I got in the truck and magically they were lit up again. Just curious if anyone has an explanation for this
Basically what Mike said. A light bulb filiment breaks that cause the light quit working. I've seen several times where the element will touch the other half and start working. Had one that blinked for a little while until the element went all the way out. Enjoy it while it lasts. I've seen them last a day or two or until you hit the next bump in the road.
Back in the "old days" when a head-light burned out, you could
smack it with your hand and that would shake the filament halves into
welding themselves back together - you did this with the lights "on".
It would usually last quite a while and repeat numerous times.
It also works on the incandescent home light bulbs too...
sandymane
05-30-2018 04:25 AM
FordPickup460
08-24-2005 06:32 AM
