Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 11-06-2012, 07:17 PM
fordtruck60 fordtruck60 is offline
Garage is empty, add now
fordtruck60 is starting off with a positive reputation.
Crown Vic IFS Complete.
Man, I thought that these would not be hard to find. Around here in Michigan, I have had no luck finding a complete unit. All the yards or craigslist, ebay, etc, just part them out. Thats alot of $ in parts. Of course thats how they operate and make their money. Any leads on one of these in my area?? Thanks
  #2 (permalink)
Old 11-06-2012, 09:55 PM
jo maoma jo maoma is offline
jo maoma is starting off with a positive reputation.
Quote:
i was running into the same problem they get torn down as soon as
they come in. i ended up making offers in advance for the complete
unit and had two yards call me up less than a week later on the same
day telling me they had them ready. it's easier for them to drop it
as a unit so they were happy to do it. might give that a try....
  #3 (permalink)
Old 11-07-2012, 06:24 AM
THartman THartman is offline
THartman is starting off with a positive reputation.
I found mine on Craigslist doing a search for P71 - the CV police interceptor.
  #4 (permalink)
Old 11-07-2012, 06:07 PM
Thanks. The search continues. I have 1 yard keeping an eye out for one.
  #5 (permalink)
Old 11-07-2012, 08:54 PM
thrifty thrifty is offline
thrifty is starting off with a positive reputation.
I travel for my job so I am looking for parts. I got a 03 and an 07 in different towns but the same state. I was told the cop cars are in demand and they are the first picked. I got lucky and got both cop versions. You might try Car-Part.com Some of the junkyards list what they have and might make your search easy. Good luck.
Jonesy
  #6 (permalink)
Old 11-08-2012, 07:13 PM
Wow! The yard that had my number actually called today and has one out of a 05 with 36K. They will have it ready early next week with all the bells and whistles including all of the frame bolts!!!!!!!! I guess I couldn't complain when he told me $300.00!! He did know what I needed it for, and is a car (truck) nut too.
So what should I use for the master etc? Also the steering column? I don't need to stay original. Thanks Again Kevin
  #7 (permalink)
Old 11-08-2012, 07:25 PM
great deal, congrats....
  #8 (permalink)
Old 11-08-2012, 08:08 PM
economan economan is offline
economan is starting off with a positive reputation.
seen on the news last week pics of the flooding in NJ a whole parking lot fulla taxis under water, most of em' looked to be vickies. most likely won't be repared from water damage that severe. i'm thinkin' that there is gonna be a mess of vickies (with the HD taxi pkg suspension in wrecking yards soon in that neck of the woods once the taxi companies get paid out by their insurances.
worth keepin' an eye out for anyone down that way.
mikie
near ottawa canada
58 merc 100 panel, 64 econo p/u
  #9 (permalink)
Old 12-25-2012, 08:37 PM
fast58's Avatar
fast58 fast58 is offline
fast58 is starting off with a positive reputation.
Kyle Brazier
I think you were asking about which master cylinder and booster to use. I used a booster out of a 2000 of so Lincoln Town Car because it has a small overall diameter. Any booster will work.
As far as master cylinders go, you just need something out of a Ford that has disc brakes up front and drums in rear. You will also need the proportioning block. This is right under the master cylinder bolted on the same bolts as the master cylinder. My master cylinder and proportioning block came out of a '98 or so F-150 because it is comparable in weight to our trucks with the same "eventual" brake setup. (The proportioning block is so that the disc brakes up front receive more hydraulic power than the drum brakes in rear.)
Check this out. Here are some pictures of when I did this swap.
http://www.ford-trucks.com/forums/11...58-f100-2.html
You may find some helpful hints in there.
PS when you go to buy new brake hoses from the parts store, buy brake hoses for a '98 F-150. The fitting types are the standard fittings. If you buy CV brake hoses you will have to also buy adapters to convert standard fittings to inverted fittings. Which creates a possible leak point. When you install the brake hoses to the frame of your truck, you can simply straighten out the bracket on the hose and bolt it to the frame.
__________________
http://www.ford-trucks.com/forums/im...ine=1324186537
1958 Ford F-100. 351 W .030 over and Speed Pro flat top pistons, Comp Cams 224/226, World Windsor Sr. heads, Edelbrock Performer intake, Holley 750 carb, Roller rocker arms, Proform one-wire distributor, MSD 6-AL ignition.
  #10 (permalink)
Old 12-26-2012, 08:21 AM
jacks61ford's Avatar
jacks61ford jacks61ford is offline
jacks61ford is starting off with a positive reputation.
or just invert flare the lines as I did
  #11 (permalink)
Old 12-26-2012, 04:17 PM
Thanks guys. Right now everything is on hold until the cash flow gods smile on me again.
  #12 (permalink)
Old 12-26-2012, 08:32 PM
Nuther' booster/master combo that worked real well for me was a 88 dodge f/s p/u
it fit soooo well i only had to elongate the holes a bit to use the factory holes in the firewall. Also seem to remember using the original f-100 pushrod without mods. Only caveat here is that the booster is too big to use iffin' you still have clutch master cyl.
I did the changeover in about 2& 1/2 hrs.
Mikie
near ottawa canada
58 merc 100 panel & 64 econoline p/u
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
