Problems filling up
Problems filling up
Here's the run down. I replaced the fuel pump on my 2000 F250 V10 and ever since it will click off the gas nozzle at 3/4 tank. So last night I tilted the bed up to see if I have a pinched vent or line. Nothing was pinched. I took off the filler neck and its connected vent line. They were clear of debris. Also, the line going to the evap canister under the hood was clear too. Any ideas on what may be causing this? I believe my year is not included in the TSB.
I went through and looked for rotten lines. All was good. Still no luck on trying to figure out what the problem is.
After the first click will it allow you to still fill up all the way? If so then I have a similar problem but thought it was just the way the tank fills. I have a flowmaster 46 gal tank, so having the tank stop at ¾ is just enough for me to catch my breath and grab my wallet before completely emptying my wallet.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
It’s an interesting problem. The only thing that I can think of is pressure building up. So there must be some sort of vent issue if all the lines are clear could it be a misrouted vent line? Maybe one of the vent or return lines was swapped. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Sorry for the cryptic first post. the tank I have is a Transflow tank. Stupid smart phones….. <o></o>
<o></o>
1eyedjack
01-20-2011 06:34 PM
