6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Tuner/Exhaust question
Old 11-06-2012, 10:18 AM
ILMathewsPro's Avatar
ILMathewsPro
ILMathewsPro is offline
Just purchased a H&S Tuner(XRT Pro) and FloPro 5" DP back exhaust. Getting the exhaust installed next weekend. It's a 20 mile drive to the shop where I am having the exhaust installed. Can I go ahead and unplug the 3 exhaust sensors, install the H&S tuner w/DPF removed and drive the 20 miles to the shop? or should I wait until the new exhaust is installed and do the tune then? I guess my question is: will it hurt anything to drive a few miles with the DPF present but sensors unplugged and the tuner installed? Thanks for any help or advice. Truck is an 08 F250, 6.4L CC.
Old 11-06-2012, 05:17 PM
Brandon D's Avatar
Brandon D
Brandon D is offline
Lead Foot User
Most new tuners bypass the sensors so you shouldn't even need to unplug them. I wouldn't run any high HP tunes until the DPF is gone but you should easily be able to make the short drive with it tuned and the factory exhaust installed. Just make sure your tuner does in fact bypass the sensors or it could throw your truck into limp mode. Cheers
Old 11-15-2012, 08:05 AM
cjb491's Avatar
cjb491
cjb491 is offline
when you install the tuner it will ask if dpf present or not. you can answer yes, then when you get your exhaust in go back and install with dpf removed. very simple.
Old 11-16-2012, 08:54 PM
RM2738's Avatar
RM2738
RM2738 is offline
Don't waste your time. No matter which you choose to do, you'll still goibg to be re-flashing your PCM at the shop immediately after the exhaust is installed.
NCMillwright
2017+ Super Duty
10-13-2018 12:40 PM
dlehmann
2009 - 2014 F150
09-29-2016 12:20 AM
KR250
13
03-01-2014 09:12 PM
Brooks Rowell
06-15-2010 12:22 AM
ehgeeray
04-15-2010 11:19 PM
Quick Reply: Tuner/Exhaust question
