Brake line pluming and bleeding
Does any one have a brake line pluming diagram for a 1950 F-6 ? I am not sure. But I think all the larger trucks are the same. As long as the carry the orginal type in frame master cylinder and power booster. These trucks are a lot diffrent then ones with just a mastercylinder. Also usually after the mastercylinder is bleed on normal trucks I start in the rear right bleading each wheel coming forward. But since these trucks have 2 mastercylinders do you bleed both of the mastercylinders first ? Or do you bleed the brake booster mastercylinder later ? Like after the rear brakes are bleed. And your working foward bleeding. This one does have the stock type mastercylinder with the brass fitting bolted to the rear of it. Were all the brake lines hook into. And thats another thing, the brake lines go into it at a specal place. So if you have it. I need the diagram on how each line goes into the brass fitting or should I say brass tubing manifold ? Thanks a lot ! Any picture diagram on the brake tubing lines,the brass manifold or information on there hookup. Will be helpful. So many brake lines and so much bleeding. THANKS A LOT !!!
Hey guys! I've redone the brake systems on a 51 F5 and 52 F6 so I'm now very experienced with these stock systems, brake booster and all. Below I'll give a general overview, but please ask questions!
The plumbing is very easy for these. You have the master cylinder (F2-F6 use NAPA NMC M4572) which sits under the driver. Out the rear of the master cylinder, you have a outlet bolt (Ford 91A-2077, available from Macs). The bolt holds in either a three socket manifold or a five socket manifold (8C-2076 for the 3 socket, available from Macs - the five socket is not reproduced). The the manifold are sandwiched between two washers (Ford 91A-2151 and 91A-2152, available from Macs). Out the head of the outlet bolt goes the brake switch (Macs C1AZ-13480-A, also available from Advance Auto and AutoZone).
If you have the three piece manifold, you do not have a brake booster. Two of the outlets go to each of the front wheel cylinders. The third outlet goes to the rear axel, where it is then split into two lines, one for each rear wheel cylinder.
If you have the five socket manifold, then it is connected up like this:
As for the brake booster, the originals (Midland C477) are no longer serviceable and are commonly replaced with the next generation booster, a C462 which almost bolts right up (Napa has them as NBB 518026)
My shop manual said that the Brake Booster was standard on the F-6. I have a '48 F6 and it doesn't have one? Does that mean it was removed? I have a 3 outlet manifold with one line to the rear as described.
I just replaced the master cylinder, here's an orig pic.
Thanx.
Thanx.
Thanx.
And kudos for finding a 3 1/2 year old thread!
5-socket manifold
Sir, I have a five socket manifold but your image does not open. Would you be able to re-post or describe in some other manner? I have hooked everything up but I get resistance to braking rather than assistance from the booster. Obviously, I have connected something wrong.
Thanx.
