Brake line pluming and bleeding
Old 09-15-2016, 08:37 PM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
I just checked online to confirm dimensions and O'Reilly has the National 5751, which is identical to the original seal, for $29.99
Mark
  #32
Old 09-15-2016, 09:15 PM
chrislynn5's Avatar
chrislynn5
chrislynn5 is offline
I'm wondering if it will work now. It shows much smaller in width:
SKF 31284 LDS & Small Bore Seal, R Lip Code, CRWH2 Style, Inch, 3.125" Shaft Diameter, 4.562" Bore Diameter, 0.75" Width
Any chance to find a replacement?
Edit: Just saw the posting before this! Thank you.
  #33
Old 09-26-2016, 02:37 PM
chrislynn5's Avatar
chrislynn5
Originally Posted by 49fordv8f4
Here is a break down from the Ford parts book for the '40-'47 axle. Yours will be the same. Number 1109 is a jack screw, there are two 7/16"-14 NC threaded holes in the axle flange between two of the nuts and 180 degrees apart. Once you remove all the nuts and lockwashers on the flange you can use those two threaded holes to move the axle out a little to remove the cone shaped rings on each stud. You can also, as df85732 suggested, strike the center of the axle flange with a 2-3lb hammer several times and bounce the cones out. I usually don't mess with the jack screws, the hammer method is a lot easier and faster. Some of the studs will probably come out with the nut. Once you have the axle out, it just pulls out once you remove the cones, you will see the bearing locknut #4252. It is an 8 sided nut about 3 1/4" across the flats. You will probably see on the corners where it has been loosened and retightened with a cold chisel or punch. You will have to remove it the same way unless you have the special socket to fit the nut. Under the nut is a keyed washer, #1124, that will need to be removed to access the inner nut #4255. After you remove these nuts and washer and back off the adjustment on the brakes, you can pull off the hub and drum. You need to place your hand over the axle flange end of the hub to catch the outer bearing so it doesn't fall out. And the hub and drum assembly is heavy, so be careful.
Mark
Your instructions were spot on. It's a feat to disassemble, and to then reassemble. I had some help from a guy that had done this before.
I also found the correct seal and put that in.
  #34
Old 09-26-2016, 02:45 PM
49fordv8f4's Avatar
49fordv8f4
It wouldn't be such a tough job if everything wasn't so heavy. Glad you got it done
Mark
  #35
Old 04-22-2019, 07:48 AM
hamptonsgarage's Avatar
hamptonsgarage
hamptonsgarage is offline
Originally Posted by bmoran4
Bleeding Order:
Brake Booster (if present)
Rear Right
Rear Left
Front Right
Front Left
Hi mate, thanks for the info on this, I am about to bleed my system. Replaced all lines and soft lines.
My question, how do you bleed the booster? Seems a silly I know but if there is a trick it would be good to know.
  #36
Old 04-22-2019, 08:49 AM
bmoran4's Avatar
bmoran4
bmoran4 is online now
The Midland C462 style booster I used has a bleeder screw just like those on the wheel cylinders to bleed:
  #37
Old 04-22-2019, 04:44 PM
hamptonsgarage
Thanks for that
fisherman_chuck
05-19-2019 07:16 PM
GB SISSON
26
07-04-2014 12:28 AM
WantFordF250
10-06-2008 08:18 PM
Dustin_86
04-24-2006 09:22 AM
god.boots
04-04-2006 09:11 AM
Quick Reply: Brake line pluming and bleeding
