Rear Springs and a special thank you - Ford Truck Enthusiasts Forums
Old 11-05-2012, 09:38 PM
Kazoo Kazoo is offline
Kazoo is starting off with a positive reputation.
Some time ago a member, whom I can't remember, posted a homemade tool for removing rear spring pins. It consisted of a 3/8 bolt threaded on one end with 1/8 in pipe threads. Built one today, took all of 10 minutes, and succesfully remove all the pins and bushings from my rear springs. Could not have done it otherwise. So a very special thank you to the member who posted this and if he is not the inventor special thanks to him too.
Old 11-05-2012, 09:45 PM
Stephen67's Avatar
Stephen67 Stephen67 is online now
Stephen67 has a good reputation on FTE.Stephen67 has a good reputation on FTE.Stephen67 has a good reputation on FTE.
Do you have a link? I could totally use that tool....
Old 11-05-2012, 09:49 PM
real simple, stephen, you cut the head off of a 3/8 bolt, grade 5 is good, thread the cut end with a 1/8 pipe thread. Thread the pipe thread end into the grease fitting hole, slide a socket, I used a 1 1/8 impact, over the bolt now put a nut on the original 3/8 bolt threads and turn away. wish I could remember the thread the poster included a picture. Real simple and works good.
Old 11-05-2012, 10:06 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
That was probably my post, I made that about 2 months ago. I posted it in the Cool Tips & Tricks thread
Old 11-05-2012, 10:13 PM
Thanks Albuq F-1, this time I saved the picture. Great tool, works great and almost free.
Removing Y block cross member filthy6 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 02-24-2015 06:11 PM
Spindle end-cap thread repair Wes66 1961 - 1966 F-100 & Larger F-Series Trucks 2 04-22-2012 02:27 PM
Mid-May Leaf Spring Special DCSpecial Vendor Specials, Discounts, Product Announcements & Group Buys 6 08-03-2008 11:48 PM
Spring Pins F1 OldgreenF1 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 09-26-2006 10:35 AM
Spring eye pin removal on 48 rear (subtitle: how do you get the dang thing out) oscarxyz 1948 - 1956 F1, F100 & Larger F-Series Trucks 20 11-21-2005 01:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
