Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 11-05-2012, 04:23 PM
vntgtrk's Avatar
vntgtrk vntgtrk is offline
Garage is empty, add now
vntgtrk is starting off with a positive reputation.
Clutch release bearing question
59 1959 Ford F Series Release Bearing - Clutch - National, PartsMaster - PartsGeek
OK so I decided to do a complete clutch job before installing my engine and trans. The question concerns the parts in the link. What I removed looks like the top part and what I got with my kit looks like the 2nd part. My engine man seems to think I just need to use the new bearing (2nd part) on the old hub without the rest of the assembly. I'm not the kind of guy who wants to install a freshly overhauled engine with a new clutch and a resealed trans only to pull it back apart. Any ideas?
  #2 (permalink)
Old 11-05-2012, 07:35 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Your engine man is right. Just replace the release bearing, no need to replace the bearing hub unless it is damaged. It's job is to hold the bearing in place when the clutch is released. So if no obvious damage, just clean it up and press a new bearing on.
  #3 (permalink)
Old 11-05-2012, 08:16 PM
vntgtrk's Avatar
Quote:
Thanks. I was able to get the old bearing off the hub without much effort using a drift and a hammer. Is that too loose?
  #4 (permalink)
Old 11-06-2012, 04:55 AM
Walston's Avatar
Walston Walston is offline
1960 Ford F-100
Walston has a good reputation on FTE.Walston has a good reputation on FTE.Walston has a good reputation on FTE.
Yes you want to use the old hub. The hub fit is not that tight. If I remember correctly, it has been a few years since I did this, there is a lip on the hub that fits against the bearing. Tap it into the new bearing and you are good to go.
__________________
Walston
http://bigjohnstractor.com/
  #5 (permalink)
Old 11-06-2012, 09:14 AM
vntgtrk's Avatar
Quote:
Thanks for the info. I did notice the bearing is made in such a way that it slips easily onto the hub when you install it backward and requires gentle pressure to push it on correctly. The designer must have done this so people with common sense would not install it backward
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
