ignition control module from a 78 302 on a59
Old 10-31-2012, 10:02 PM
rodriguezfords's Avatar
rodriguezfords
rodriguezfords is offline
can some tell me how to wire this to my 59 f100. the engine is a 78 302 and i can get the module from auto but how do i wire it. thanks for the help
Old 10-31-2012, 10:35 PM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
Try this link i found with a google search.
http://www.michellesfords.com/Wiring_diagram.jpg
Old 10-31-2012, 10:44 PM
rodriguezfords
i looked at that link and everything makes sense but the green wire is shown within the 4 pin connecter how do i take it to the selnoid. also do you think they sell the two piece pin since i dont have it?
Old 10-31-2012, 10:56 PM
theodore/teddy
Refyred
I'm not sure I follow your question. The green wire goes the - side of the coil. I think a junk yard would be a good source for the connector.
Old 11-01-2012, 07:09 AM
rodriguezfords
Old 11-01-2012, 07:10 AM
rodriguezfords
on the diaghram that green wire goes to the selinoid
Old 11-06-2012, 10:30 AM
theodore/teddy
Refyred
Sorry for the late response I've been out of town.
Is this the diagram you are looking at? I'am color blind but if I read it correctly the green wire goes to the coil. If pressed you could just cut and splice the wires from the controller and run them to where ever they need to go.
But then again you have probably got the truck running by now.LOL
Good luck in your quest!
4x4lugnut
Electrical Systems/Wiring
05-10-2011 09:12 PM
RANewman
1947 and Older Ford Trucks
11-26-2010 09:51 PM
donatorc
08-19-2010 06:36 PM
wolverineflight31
08-04-2003 09:58 PM
Quick Reply: ignition control module from a 78 302 on a59
