Updated HPOP cover for 05 psd?
Old 08-31-2012, 07:25 AM
FordMan35's Avatar
FordMan35
FordMan35 is offline
Is there an updated HPOP cover for the 05 thru 07 MY PSD'S? It seems to me I remember reading something about this in the past, but I can find a thread on it. Can anyone tell me what the differences is are, and if it is worth changing? I think my STC fitting is on its way out, and I will be in there this weekend. It is is worth the upgrade I want to do it.
Old 08-31-2012, 08:36 AM
zhilton's Avatar
zhilton
zhilton is offline
I'm fairly certain the change was between '04 and '05 models. The earlier trucks with the older style cover don't have the STC fitting.
Old 08-31-2012, 09:02 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
Here's a few pictures of the cover on my 2006. not shure what they could update?
Cover off:
Cover on:
Old 08-31-2012, 09:48 PM
FordMan35's Avatar
FordMan35
Thanks for the clarification guy's. I know about the change between the 03-04 to the 05+. Just thought I remember reading about an updated cover for the 05+ MY. Tomorrow I will be doing a few tests to determine if I have a HPO leak, and were it might be(hard starts). I am thinking I may just go through and replace the STC fitting along with the stand pipes and dummy plugs anyway even if I don't find anything.
Old 11-03-2012, 12:53 PM
Rmblanchard2's Avatar
Rmblanchard2
Rmblanchard2 is offline
What kind of sealant do you use on the hpop cover when putting it back on?
Old 11-03-2012, 02:06 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Just a little silicone at the rear plate and block junction. Otherwise it is an o-ring seal.
Josh
Old 11-04-2012, 12:08 PM
FordMan35's Avatar
FordMan35
I used the Ford stuff. TA-29. It is pricey, but I didn't want to take any chances.
I have read that certain sealants can cause the oil to foam.
Old 11-04-2012, 01:17 PM
Bullitt390's Avatar
Bullitt390
All you need is a couple blobs of sealant at the block seam. You don't silicone the entire cover onto the block.
Josh
Old 11-05-2012, 05:17 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
I know there were updated covers for the 03 and 04 model engines because of issues with the cover rubbing a hole in the HPO lines. I'm not sure that the late model covers have that issue.
Old 11-05-2012, 05:26 AM
bismic's Avatar
bismic
bismic is online now
Received 2,449 Likes on 1,696 Posts
I've not heard of it either.
Brent376
2017+ Super Duty
01-18-2019 06:15 PM
Goose05
2004 - 2008 F150
06-08-2008 11:53 PM
Cole26
09-12-2007 10:05 PM
mylo
2004 - 2008 F150
10-04-2005 04:59 PM
VintageRR
1999 to 2016 Super Duty
10-21-2004 03:19 AM
Quick Reply: Updated HPOP cover for 05 psd?
