Loaded down and headed out! - Ford Truck Enthusiasts Forums
Old 11-04-2012, 09:31 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
We finally got everything loaded into the trailer today. With the exception of some odds and ends the trailer is completely loaded as high as the ceiling all the way to the back door. Inside is all the worldly possessions that we are moving from our house here in Amery, WI all the way out to Manchester, CT. The trailer is equipped with tandem 7K axles, and a GVWR of 14,000 lbs.
My main goal today was to get a sense of how heavy the trailer was, how much tongue weight I had, and exactly what the WD kit did to the axle weights. All of them were being compared against this, which is my empty Excursion with a full tank of gas and nothing else.
Which matches up quite nicely with the advertised curb weights. So I roll onto the scale without the WD kit installed, and here's what I come up with:
So, 6,280 + 2,820 = 9,100 lbs. Subtract the 7,360 lbs and we have a tongue weight of 1,740 lbs! It's not quite that bad, as I probably had another 40 lbs of spring bars and wheel chocks int he back, so I figure I have right around 1,700 lbs of tongue weight. Total trailer weight is right at 14,160(which is fine), but the tongue weight is FAR over my target of 1,000 lbs!
So, to continue, I drove around and hooked up the WD kit and went around for a reweigh:
Wow. Those spring bars really do move some weight! 580 lbs went back onto the front axle, and 220 lbs went back to the trailer axles. Now with this my steer axle is close to what it originally was, and the drive axle is still comfortably under it's 7,000 lb GAWR. Subtract the 220 lbs that went back onto the trailer axles and I still have 1,480 lbs on the tongue. Here's a shot at the Walmart parking lot on the way back:
I did add increase the rear airbags another 10 PSI to a total of 40 PSI in each bag.
So the load plan is to take all 500 lbs of topsoil that I have sitting outside my shed and find a way to stick it in the very back of the trailer. Don't remember my exact measurements, but this should remove ~250 lbs from the tongue. Still way over where I want to be, but that's the best that it's gonna get.
On the upside I was truly amazed with how well the Excursion did with that much trailer weight. I do have the optional 4.30 gears, but I was still 40% over the maximum rated trailer weight! Had no trouble moving that much weight at all, I just took my time and stayed around the speed limit. Only had to downshift to 2nd gear once, and that was only to see how well I could maintain speed up the steepest hill around here. To my utter surprise I had no trouble holding overdrive along all flat stretches of road and even some slight inclines! Maximum recorded RPM with my ScanGauge was 3,750 RPMs, and I never got under 52 MPH the entire 60 mile trip to and from the truck stop. Trailer sway was more pronounced than it was under similar situations with my Super Duty trucks, but that's to be expected because they weighed over 8,000 lbs and had the longer 156" wheelbase.
My modified transmission cooling setup performed exceptionally well, with the transmission temps climbing quickly into the 180 and never exceeding 190. The ambient temperatures were in the low 40's, so this shouldn't have been particularly challenging to the gigantic 6.0L cooler that's riding up front, but it's good to see the Derale thermostat is working well.
After putting the final touches on the load tomorrow we head out. Hoping to make it to South Bend, IN assuming all goes well. I'll be cruising at a nice and leisurely 60-62 MPH to be easier on the wallet, and I hope to have a nice, easy ride.
Old 11-04-2012, 09:39 PM
AlaskanEx's Avatar
AlaskanEx AlaskanEx is offline
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
looks great! i sure hope after all your work you've put into her in the last month or 2? pays off for you! my thoughts are with you and hope this trip goes safe and sound with no issues!
make sure to update us with MPG numbers and your opinion after the trip.
be safe! if your feeling tired pull over. i have a issue with falling asleep on long drives, hope its not a issue you have.
Old 11-04-2012, 09:45 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Ya done good, Tom.
Safe travels buddy.
Stewart
Old 11-04-2012, 10:01 PM
A/Ox4's Avatar
A/Ox4 A/Ox4 is online now
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
I like to pretend my little trailer is bigger than it is... But it weighs something like 3800lbs hehe. Its like its not even back there. I stop faster because of the trailer brakes
Someday I will get a proper sized trailer, but for now, borrowing dads will work.
I have trailer envy.
Old 11-04-2012, 11:19 PM
Karlsgems Karlsgems is offline
Karlsgems has a great reputation on FTE.Karlsgems has a great reputation on FTE.Karlsgems has a great reputation on FTE.Karlsgems has a great reputation on FTE.Karlsgems has a great reputation on FTE.Karlsgems has a great reputation on FTE.
Good luck, Tom. We're all rooting for you. It's been awesome to see you polish away the rough edges of your Ex and reveal the true gem within.
You're gonna have an awesome trip. And we will all be interested to hear how it goes (especially us v10 owners!).
Can't wait to have you up and running again so we can read your posts!
Good luck
Karl
Old 11-05-2012, 01:33 AM
archtaan's Avatar
archtaan archtaan is offline
archtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputation
Safe travels and thanks for the info!
Old 11-05-2012, 06:13 AM
golfmedik's Avatar
golfmedik golfmedik is offline
golfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputation
Safe travels!
Old 11-05-2012, 07:15 AM
Tom's Avatar
Haha, I feel the same way when towing my boat!
3,500 lbs just doesn't seem like enough.
Busy day today, we have to finish up everything and then get on the road. Hoping to leave by 10:00!
Old 11-05-2012, 07:57 AM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
On the upside I was truly amazed with how well the Excursion did with that much trailer weight. I do have the optional 4.30 gears...
I wish more people would go to the same lengths to ensure their trailers/vehicles are properly loaded. Some of the rigs rolling down the road truly amaze me.
I have a question. Is there a reason you don't run more air in the airbags? I know the ride is compromised the more PSI you run, but I think you might be able to run more air pressure in order to transfer some weight back onto the trailer. That would mean you don't have to pay good money to haul 500 pounds of dirt.
I really think that V-nose trailer is going to make a huge difference in how much fuel you (don't) burn. That and the 4.30 gears will make your 60-62 MPH speed the "sweet spot" for power and MPG. I know my V10 and 4.30's really work well together at that speed for MPG.
I really look forward to hearing your numbers when the trip is done.
Old 11-05-2012, 08:07 AM
Tom's Avatar
Quote:
Thanks Jeff. I was a professional truck driver for a few years, and I am still a CDL holder, so weight matters to me. Even though I'm a business major I also have a fair appreciation for physics as well.
My problem is tongue weight, and the trailer is sitting level the way it sits. Every 10 PSI in the bags adds 500 lbs of lifting capability, so with 40 PSI I'm adding 2,000 lbs of lift force to the rear suspension. Stock the truck sits over 3,700 lbs on that axle, so with 40 PSI I'm now effectively sprung for 5,700 lbs with extra capacity to spare with the factory springs, as they can handle another 1,000 lbs even without the bags. My concern is that if I stiffen the rear suspension too much the shock on the hitch will be greater when I hit bumps, and that could work to rip the hitch from the frame.
I guess I should stop procrastinating and get to work...
Old 11-05-2012, 08:59 AM
That makes sense.
I was thinking you could adjust the hitch height to lower the trailer tongue, then add air pressure to the bags to raise the back of the X until the trailer is again level. Now I understand what you mean.
I have very little experience with air bags (although they are on my wish list) so I am looking at your setup for future reference.
Old 11-05-2012, 11:22 AM
king-david king-david is offline
king-david has a very good reputation on FTE.king-david has a very good reputation on FTE.king-david has a very good reputation on FTE.
Let me know if you get to Eastern Pa and decide to stop. I'll meet up with you and buy you a drink! How long do you anticipate the trip taking?
Old 11-05-2012, 12:14 PM
Wow, Tom that is a long trip (I just google mapped it).
I had a Navy buddy who was from Bloomer, his dad owned a bar there.
How long are you planning the trip to take?
Old 11-05-2012, 06:51 PM
Monster-4's Avatar
Monster-4 Monster-4 is offline
Monster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud of
Safe travel Tom! Looks like you got it pretty well balanced.
Old 11-05-2012, 07:05 PM
79malibu 79malibu is offline
79malibu is gaining momentum as a positive member of FTE.
is that a race trailer? if so i'll meet you at the track next summer
2013 Millersburg Meet results with HD video! Tom 1999 to 2016 Super Duty 143 05-18-2016 05:14 PM
Why does everyone complain about the rear springs? (UPDATED with more weight) Tom 2009 - 2014 F150 17 09-06-2013 10:26 PM
Third heavy tow Tom 2009 - 2014 F150 8 08-13-2013 10:29 AM
Second heavy tow! Tom 2009 - 2014 F150 24 06-19-2013 03:35 PM
The X made me proud... Tom Excursion - King of SUVs 6 04-14-2013 10:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
