Changed fuel filters-won't stay running
08 f250 with 6.4, changed both fuel filters this afternoon. Truck started right up then died. Did some reading after that & primed it many times with key on/off. Takes a long time to start then dies after 5 sec or so. Sounds normal when it runs. Wrench light is now on. Filter lids are on tight, pulled top one back off & it didn't have alot of fuel in the bowl so I turned the key to run the pump with the lid cracked & it filled all the way up. Still does the same thing. Takes 10 seconds to start if it even does, then dies after 5 seconds or so. Also disconnected batterys for 45 minutes hoping to reset wrench light. Didn't work. Anyone know what the heck happened? Trying to prevent problems with the truck & it backfired on me!
Got it fixed. Air in the system. Had to remove the 17mm banjo bolt on the rear of the fuel cooler. Hold a rag over to block fuel flow & it still went all over. Just let the line hang but be careful not to lose any washers. Prime again & start, let run for a little bit then shut off & reassemble. Fixed me right up, wrench light went off allready too. Thanks to Chris at C & C diesel in Bennington, NE.
Hopefully this may help others in the future.
The schrader valve is for low pressure side bleeding, the high pressure side has to be done from the other banjo fitting.
If you properly purge the air out of the LP side with the key cycling (more than the six cycles in the manual, at least 10 while listening for air returning to the tank) you will not have to purge the HP side.
If you try to start without purging the LP side it can force air into the HP side and then you'll be dead in the water until you do the HP purge. Getting air into the HP side can also cause damage to the HPFP.
http://wpnet.us/Fuel_System_Bleeding_LP.pdf
http://wpnet.us/Fuel_System_Bleeding_HP.pdf
I recommend printing these docs out and keeping them in the truck so you have them available should you have an issue.
Lane_08
6.4L Power Stroke Diesel
05-11-2014 08:22 PM
Seantexastech
20
07-03-2010 12:31 PM
95mazdab4000
1983 - 2012 Ranger & B-Series
38
02-07-2010 08:02 AM
