1995 F-150 Trans prob - Ford Truck Enthusiasts Forums
Old 11-04-2012, 04:17 PM
dcrank dcrank is offline
dcrank is starting off with a positive reputation.
I have a 95 ford F-150 4x4 brand new trans. I drive down the road it shifts out fine till you get to 50mph or better and it seems like its jumping back and forth between gears anyone have any suggestions on what it could be or what to try. I've replaced computer rebuilt trans fluid level is where it should b im stumped what should i try next?
Old 11-05-2012, 07:33 AM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Sounds like bad wires going into the plug that plugs into the transmission on the passenger side.
Old 11-05-2012, 07:44 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Is it on stock rims and tires?
What engine?
Old 11-05-2012, 07:53 AM
subford's Avatar
What transmission do you have also?
Old 11-05-2012, 11:29 AM
FordNFl FordNFl is offline
FordNFl is starting off with a positive reputation.
Mine does this around. 40. Rpms go up... Then go down...then go up...then go down. There is a tsb on the transmission wiring harness. As mentioned by subford Havent looked at mine yet. Mines e4od. Soon to be manual.
trans Tractorman1215 1987 - 1996 F150 & Larger F-Series Trucks 4 05-31-2013 09:41 AM
1987 F150 302- 3spd manual overdrive -4wd corbins 1987 - 1996 F150 & Larger F-Series Trucks 4 09-12-2011 11:03 PM
best trans for 351W jklapp86 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 04-01-2008 06:30 PM
1978 Engine and trans swap question OregonGuy1978 1973 - 1979 F-100 & Larger F-Series Trucks 6 08-20-2007 07:07 AM
trans ? njtinman2 1987 - 1996 F150 & Larger F-Series Trucks 1 09-02-2006 02:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
