What are these wires?
Doing a front end upgrade on my 1999 F350 Dually Lariat. When I took off the grill I came across this connector located next to the radiator on the drivers side.
It has two wires, one appears to be green and with a red (perhaps orange) stripe, the other is white with a red stripe.
I'm also going to install fog lights and wanted to know if I could tap into this connector and use an OEM switch of some sort. Note, that the origin of the two wires is at the wiring harness for the front lights (on the drivers side).
Haven't found a wiring diagram that shows these wires.
Thanks in advance
Thanks in advance
Kremerica
6.7L Power Stroke Diesel
06-29-2019 08:08 PM
460 FORD MAN
22
08-10-2012 04:34 PM
