a/c problems need help
Hey guys, I got a 92 150 with a 5.8L. My a/c used to work perfectly, one day it started blowing warm. The compressor kicks on and off at short intervals, I tried re-filling the system with refrigerate and the pressure held but still no cold air. I'm wondering what the problem is or how to narrow it down step by step. The air still blows, just the temp outside however. I'd appreciate any help given. Thanks!
When the a/c originally started short cycling it was because the refrigerant leaked out. If you did not fix the leak then any new refrigerant introduced has or will leak out. The air that has gotten into the system will raise the discharge pressure reducing cooling capacity. Any moisture in the system will tend to freeze in the orifice tube.
To convert to R-134a you will need to .
Have R12 removed.
Fix leak
flush system
Replace orifice tube(the screen is probably full of trash/debris)
install fittings
Evacuate system
charge system with R-134a
matt
Have R12 removed.
Fix leak
flush system
install fittings
Evacuate system
matt
smashclash
07-01-2013 10:59 AM
mrgomerpyle
05-06-2005 04:12 PM
