I just bought a '90 F150 with only 74000 on it. 2H and 4H work great, but it won't go through the gate to put it in 4L. It looks like it's pretty corroded, so I have been spraying it down with PB Blaster for a few days, to see if I can free it up. Does anyone have any input or advice on how to proceed in freeing up this linkage? Thanks, Johnnyfever
Very easy fix, remove the bolts holding the linkage on and take the linkage off entirely and coat all the moving parts with anti-sieze. Same thing happened to mine.
Whatever you do, do NOT try and force it into 4L. You will break the linkage, and it is next to impossible to find a replacement.
Hey Alex, Thanks a ton for the tip on the frozen linkage. I took it apart this afternoon, and cleaned it up real good. Then I coated all moving parts with anti-seize. It worked great. It now goes into 4L and works perfectly! Thanks again for your help. Johnnyfever
I'm glad I could help! Also glad to hear that you can get it into 4 Low now.
