98 ranger 4.0l o2 sensor bank 1 sensor 2 help - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 11-04-2012, 10:58 AM
Mike Halsey Mike Halsey is offline
Mike Halsey is starting off with a positive reputation.
Good morning. i ran my scanner on my truck to day and my 2 bank 1 sensors seem to be bouncing between .150 and .700 but my bank 1 sensor 2 seems to be stuck at 680-720 and not bouncing, is this normal?
i did pull a code po135 heater circuit malfunction BANK 1 SENSOR 1
Also im not sure where my fuel trims should be
my
ST1 10.0
LT1 25.0
ST2 12.0
LT2 25.0
closd loop.
when i first got the truck i pulled codes for lean bank 1 and 2 also a cylinder #4 misfire and the bank 1 sensor 1 heater circuit. i reset the codes and the heater circuit bank 1 sensor 1 poped the mil light in 5 min. so im starting with the o2 sensors. iv not found any vacuume leaks at this point.
thanks
Old 11-04-2012, 07:56 PM
pawpaw pawpaw is online now
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
Welcome to FTE.
Are the fuel trim numbers + Positive. or - Negative?????
+ numbers indicate the computer is having to Add fuel to compensate for a lean air/fuel ratio. A - number indicates it has to Subtract fuel because on an over fueling problem, causing an overly rich air/fuel ratio.
Its normal for the upstream/before cat converter O2 sensors to switch fast within the range you posted & for the down stream/after cat converter O2 sensors output to remain steady, if the converter is doing its job.
The P0135 code suggests that their is a heater problem with the upstream bank-1 O2 sensor. This will cause the O2 sensor to be slow to heating up & coming online.
Old 11-26-2012, 09:29 AM
bmerr98's Avatar
bmerr98 bmerr98 is offline
bmerr98 is starting off with a positive reputation.
I had a similar code a couple years ago. Ended up being a leaking egr valve. There's a diaphragm in it that tends to go bad after a few years. Gives a lean reading and essentially allows unfiltered air into the engine. Might do a smoke test before spending $ on O2 sensors and such.
Old 11-26-2012, 09:56 AM
my
ST1 10.0
LT1 25.0
ST2 12.0
LT2 25.0
closd loop.
thanks
After re-reading your post I see I didn't answer your after cat (bank-1 sensor-2) question. Yes its normal for the after cat O2 sensors output to be fairly steady, as its normal for it to have a fairly flat curve & not switch like the upstream sensor), if the cat converter is healthy & doing its thing.
^+1 on a smoke check to find vacuum leaks. If you come to suspect a vacuum leak, you can do a home made check by blowing smoke (aroma of your choice) lol, into a vacuum line to check it, or the intake manafold, or any other vacuum operated system thats suspect.
More thoughts for consideration, keep us posted on your trouble shoot.
Chasing O2 Sensor codes lacyctdy 1987 - 1996 F150 & Larger F-Series Trucks 9 05-03-2016 12:53 AM
1996 F350 O2 Sensor Codes P135, P136, P141 and P155 jmlkicker 1987 - 1996 F150 & Larger F-Series Trucks 0 08-04-2015 01:00 AM
2004 Lincoln Navigator - 5.4 Intech - P2197 O2 Sensor Signal Biased/Stuck Lean (Bank 2 Sensor 1) Kid Clean Expedition & Navigator 18 03-03-2015 10:23 AM
O2 Sensor Help svtcobra041 1997 - 2003 F150 2 07-15-2010 10:19 AM
Check Engine Code P0155 ( bad 02 sensor )? MikeRizz Excursion - King of SUVs 4 03-24-2010 10:56 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
