It seems that when I press the brake pedal on my 2000 F250 my dash lights come on. I did a search and came up empty. Anyone have a clue of what might be causing it?
Headlight switch and dimmer works normal. Any time I depress the brake pedal the dash lights come on when the headlight switch is off. I do hear a clicking sound when I press the brake pedal, that is how I noticed the dash lights coming on.
Well I thought I had the problem figured out with the ground, but it was not to be. After I cleaned up the ground I jumped in the cab stepped on the brake pedal, and still had the same problem. The other thing that I noticed was when I turned the lights on the third brake light came on. I disconnected the rear light harness and stepped on the brake pedal and the dash lights did not come on. So I determined that the cause of my woes was coming from the rear light harness. I removed the harness from the utility body and started to ring out the cable. I noticed that Brown wire for the driver’s side light was missing even though I remember it being there when I started the removal process. A little further investigation revealed where some mice decided to have a little snack on the Brown and Light Green/Orange wires causing a short. Repaired both wires re-routed the harness into the body, hooked up the lights and everything works as it should.
