Carb For my 1971 Ranger XLT?
Hi Guys,
Well, I'm having loads of fun hunting down items to pep up my 1971 Ford Pickup (360). One of the things I want to do is put on an aluminum high rise intake & 4 BBL Carb.
There's a guy nearby me that has a Motorcraft 750 4 BBL that was running fine, and just came off a Ford 460 V-8. I can get it for $50. Does that sound like a good fit? Thanks for any help. I really appreciate it.
Bob
Bob
Hi Bob, Welcome to FTE & the BUMP forum.
No sir, DO NOT buy either. The 360 is an early emissions engine, while it is still a horse, it is considered a dog by many. About 600 cfms is all that engine can handle and it can handle it well. It is a pulling engine not a hi revving race engine.
Suggest you start on a plan to rebuild one day, using 390 crank & rods, Edelbrock Performer or similar intake, add headers, a RV cam and you can have that big horse.
John
John
John
John
Bob
Originally Posted by Corkwheats
I found some stock 360 4BBL intake manifolds.
1965/71 390 4V Passenger Car intake manifolds will bolt right on 360's, as will 1974/76 F100/350 390 4V intake manifolds. But, these manifolds are cast iron, just like your 2V manifold, weigh a ton.
Try reachin' over the grille or fender to remove one a these manifolds by yourself. Not an easy nor a pleasant experience.
What you might have found is some 1973/78 361 4V cast iron intake manifolds. PASS, you don't want any! The 361 is an FT engine, only installed in 500 and larger trucks.
360/390's share the same engine block, the bore (4.05") is the same. The stroke is different: 360: 3.50" / 390: 3.78"
All that's necessary to convert a 360 to a 390 is the 390's crank, rods, pistons and rings. EVERYTHING else is the same.
There's no such thing as a 360 4V intake manifold. 360's were only installed in 1968/76 F100/350's and all came with 2 barrel carburetors.
Is it your opinion that an aluminum intake, such as an Edelbrock Performer, etc., manifold would be better? Just as long as I don't "over-carb" it, and stick with a 600 CFM?
Thanks,
Bob
Just because it's an FE engine doesn't mean the parts will interchange. 1958/64 FE engines were only installed in Passenger Cars, have rounded valve covers without holes in them for oil cap/smog valve.
Have an oil fill tube on the right (passenger) side front of the engine. The bolt pattern on the block for the right/left steel/rubber insulators is different than 1965/71 FE engines.
The flywheel has 148 teeth, 1965/76 has 184 teeth. Three different 1958/64 FE waterpumps, none are the same as 1965/76 that use one waterpump. And the list goes on and on.
btw: Do you think your friend at the local shop that 'verified' the "14,000 actual" miles would know some/all of this jazz? Probably not.
I know your truck pretty well as I bought a 1971 Ranger XLT 390/C6 brand new, was a Ford partsman for 35 years (1962/97) and have been in this hobby since Ike was prez.
Absolutely, why mess with a cast iron manifold if you don't have to.
I'm the dummy here - just trying to learn some of this on my own. I don't plan on trying to make a hot rod out of this truck. I just want to have some fun, and boost it a bit in an "old school" sort of way.
I haven't messed around with cars since I was a kid. My first ever vehicle was a 1964 Ford Fairlane w/260 V8, 4 BBL, 4 Speed. The man who gave me the $ to buy this truck used to have a 1968 Ford Torino GT Fastback with a hot 390 in it (from the factory!). He currently has a cherry 1974 F100 w/360.
So, I just really appreciate all the expert info from you guys. I'll take all I can get! Thanks!
Bob
I put one of these Holley 2300 Street performers on my 390 recently, Love it! Was extremely easy to tune right out of the box and seems to be a great match for the truck, Its pretty much a bolt on and go carb.
AND best part, you keep your stock 2bbl intake manifold.
Holley 0-4412S Holley 2300 Street 2-Barrel Carburetors & Kits
John
I have pretty much settled on that - My plan is to get a Professionally Rebuilt Holley 600 CFM (Model 4160 - $215) with a stock 4 Barrel Intake manifold that I can get for about $50 - $75.
Like you say - I'm not building a street rod. Just pumping it up a tad. Basically, it's going to be used to haul hay. I just want to have a little fun. I have a local guy who is going to put on a quality low restriction dual exhaust w glasspaks, as well. I'm not sticking a cam, etc., into this puppy.
Thanks for the info!
Bob
Hi Guys,
I'm planning on going with a Holley 600 CFM Carb (Model 4160). I don't need any more than that. Can anyone tell me what the "Ford Kickdown" on this carb is? Is that important? And, do I need electric choke or manual?
One last question - I'm looking at some stock used 4 BBL FE intake manifolds for my 360. In another thread, there was a discussion about the "S" manifolds vs. the "T" manifolds. I'm guessing there will be a big S or T that I'll be able to see. Which one would be best for my 360?
Thank you all so much!
Bob
Bob
dilmachender
07-24-2014 05:36 AM
76HighboyGuy
24
07-17-2010 04:32 PM
Big Skier
18
03-31-2008 08:07 PM
YoungMT Hick
16
03-18-2007 12:05 PM
Damon Dimick
06-13-2003 07:05 PM
