1952 F1 Wiper Switch to Motor Wiring 12VDC Question
I have been search the forum now for awhile using the wealth of information and pictures to put my 1952 F1 project truck together. This is mt first post.
The truck has been converted to 12 volt thanks to forum. I am at the point of installing the electric wiper motor that came in one of the 100's of boxes of parts which were with truck.
The original 6V wiper switch has a F, A, P, B post label. The B post is a tall points operated circuit breaker extending well past the switch housing. it is a COLE switch. The new 12VDC switch I purchased is also a COLE switch with a F, A, P, B post labeled.
The wiring harness I purchased from one of the many Vinatage House's came with three wires, Black, Green, White.
When all was said and done with wiring the dash I ended up with two hot wires a blue/black and a solid yellow in the same casing going no where. i figure these are to be used as require where you need 12VDC. I am going to assume the Motor is 6VDC and I will need to put a voltage reducer on it. So what wire do I place the reducer on? And what wire should i run to switch that brings in the 12VDC.
See the sketch below. There are no diagrams in the 52 Shop Manual on how to wire switch or motor. Manual just talks about them. So see my skecth below. Any help would be greatly appreciate.
Last edited by travelingman55; 11-03-2012 at 08:44 PM. Reason: Picture did not take
I have black, green and white wires, I want to make sure they are plugged into the right position on the parking switch, I can get the correct relationship on the switch from there.
The lower contact is shorted internally in the switch to the power contact so it has power any time the right contact has power (switched).
This is an interesting device, in that it has power all the time going to the central contact on the parking switch. When you turn off the wiper switch, the park switch/cam function provides 6 volts to both sides of the motor, which equals 0 volts difference in potential, so the motor shuts off.
It took me hours to figure out how it worked. That's why, if the motor is going really fast (like you don't have drag on the wiper blades), and the switch is turned off, sometimes the wipers don't stop, because the kinetic energy of the motor moves the cam off the park switch and re-completes the circuit for the power to the motor.
Does that make any sense at all?
Yes.
The Forum is like the Tooth Fairy but better. I went to sleep last night with a question under my pillow and woke up to $70.00 worth of answers. Thank you all so much. Two more questions since the manual doesn't cover this.
1. How would you add the labels F, A, B, and P to the diagram above? Both at switch and motor?
2. Where would you bring power to switch from. Ignition Switch?
I don't know about the labels. I don't recall seeing them. I made sure when I disconnected the wires that I marked them, so I could reconnect them correctly.
scottlathrop
07-02-2017 11:36 PM
66F100Again
20
06-21-2017 04:00 PM
C.P.
10-24-2014 06:54 PM
bmaltb
04-26-2007 08:53 PM
53Trucker
09-27-2005 11:27 PM
