steel grill wanted
I'm alittle confused. This is in the 67-72 forum so any steel grill outside those years won't work for me.
My truck is a 71 and I did post about the 71 grill. My plans have changed and I want to paint the grill to match the truck and I would like it in steel. I looked on the fortification site at the 67-69 grills and I don't really see a huge difrence.
Maybe someone could post a pic or explain the differences?
If you got one maybe send a pic and we could talk. I'd prefer a local pickup because I'm sure the shipping would really suck
Thanks for all the help guys
1967/69 F100/350 Custom Cab/Ranger came with anodized aluminum grilles and anodized aluminum headlamp doors.
Only 1967/69 F100/350 Standard Cabs came with painted steel grilles, painted steel headlamp doors.
1967 grille is 1967 only, 1968/69's use the same steel grille. Steel headlamp doors are the same 1967/69.
1967/69: The parking lamps are different than 1970/72, mount into the grille below the headlamps.
1967/69: The stone shield that is located below the grille is dished at either end to allow for grille clearance.
1970/72: The stone shield is different at either end than 1967/69, as this is where the 1970/72 parking lamps bolt to.
Consider painting the anodized aluminum grille/headlamp doors you have now, instead of going thru all the labor and expense of swapping in 1967/69 parts.
One of the main reason I want to swap from the 71 to the 67-69 grill is because I like the look of the parking light on the 67-69 setup.
Right now the truck is a cab and chassis only, today I will be putting in the crown Vic ifs, so the extra work is not a concern at this time
So with this info ND posted, I will need the stone guard aswell.
Thank you everyone
Thank you everyone
hotrodhenson
09-23-2008 05:52 PM
steve66
04-17-2006 04:56 PM
