Rebuilding a 400-500hp tow engine - Ford Truck Enthusiasts Forums
Old 11-03-2012, 02:27 AM
greatwhitef350's Avatar
greatwhitef350 greatwhitef350 is offline
greatwhitef350 is starting off with a positive reputation.
Turns out i have a cracked piston so I want to make sure I rebuild my engine reliable with 400-500hp tow motor. I called Clay and he has the ford rebuild kit and he could machine the piston and ceramic coat them also. He also has the comp 910 springs and push rods. Anything else you guys recommend for more reliabilty and possibly getting me the horse power i'm targeting. I will be getting full force stage 2 sticks along with the other mods i already have.
Old 11-03-2012, 04:25 AM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant future
Quote:
Better tunes. I have (2) engines w/cracked pistons sitting on my garage floor right now... It took me a minute, but I came around before the 2nd one broke (after those toons for 70k miles, it was too late though...). After experiencing the difference in better tuning, I could never go back. Those still taking the koolaid can say what they want.
You might consider head studs. I'd definitely recommend a T4/S366 and 160/100's - probably the perfect 'tow rig' combo. Ya probably need more like 238/100's and maybe more air to get to 500HP - but it'd still be a good tow rig with the right tunes.
With AC codes (160/stock nozzles) and 38R, my truck dyno'ed 370HP in 'hot' tune and 320HP in 'tow' tune. This is a towing animal and EGT's are never a problem - but bigger nozzles would have given me more power without any real trade-off's..... (except the option to consume more fuel! )
I do have a set of coated Int'l up-pipes and a coated 38R (came from Clay ) for sale in the classifieds!! (shameless plug )
It sucks this happened to you, but I know you'll be happy with the new engine at the power you are lookin' for!!!!! Post some pics of the carnage.
upgade options KAGAN21 1997 - 2003 F150 17 02-01-2016 08:22 PM
project truck tjr8911 1987 - 1996 F150 & Larger F-Series Trucks 2 08-02-2015 04:32 PM
which big block? mike k m 1961 - 1966 F-100 & Larger F-Series Trucks 29 07-09-2014 10:25 PM
Body Plate Decode - 1964 Econoline Pickup ApocBane Ranchero & 1961 - 1967 Econoline 1 09-06-2013 05:39 PM
Testing the coolant clutch fan??? pjnadon 6.0L Power Stroke Diesel 12 02-14-2011 09:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
